I purchased this recently to add to the collection.
Appears as New Old Stock with box, wrapping paper, warranty.
From what I have seen here on the forum, the serial number can be inconclusive as detailed records are lacking. However, the blade on this knife is 5 inches, rather than 4 1/2 inches which indicates to me that this is an original series knife made of L6 steel.
Am I wrong?
Thanks
As you've discovered, there are 2 versions of the Mk 1 - 5 and 4.5".
Unlike the Mark II, apparently no accurate records were kept regarding the dating of the Mark I Gerbers. However, according to the following referenced site, the 5" versions were made between 1976 and 1980, while the 4.5" verisons were made from 1981-1987.
Also those made between 1976-1981 were purportedly made w/L6 tool steel while those made later were purportedly made w/an unidentified "high carbon surgical stainless steel " - probably 440C as was used in the Mark II).
See:
http://knifecollector.net/GerberMKI_Info.html
However, I'm not sure how accurate this information is because I've got 2 Mark I's and neither of them is either exactly 5 or 4.5" long.
One is 4 7/8" and the other is 4 3/4" long; the former is numbered 087982 and the later 131121.
I believe (but cannot verify) that any Mark I that uses a letter in the serial number (as found on the Mark II's) are later in mfg than mine, as is the case w/the Mark IIs.
The dating and construction of Mark II Gerbers is much more accurately recorded. See:
http://militarycarryknives.com/MKDATETABLE/MkDateTable.htm
My guess is that my Mark Is were made around 1980-1981 using 440C steel, since they predate the use of letters and 440C in the Mark II beginning in 1982.
I also have a Mark II numbered 085606, which is I identify as made in 1980 w/440C steel consistent with this information.
BTW, sorry to tell you that the nylon sheath (as well as the letters in the serial number) almost certainly marks your Mark I as a much later model, regardless of the length which apparently was NOT carefully regulated based on the length of my knives.
Older Mark Is only came w/leather sheaths.
Your Mark I is still a GREAT boot knife, regardless of the date of mfg, but it might not be worth what you paid for it, it if was represented as older than it really is. My guess is that is was made in the 90's.
