- Dec 10, 2017
Hey, I’ve got a Germantown Hewing hatchet. What should the bevel be on the edge and should the edge be straight or have a banana shape to it?
About as succinct and accurate a reply as you could wish for!We would need to see your hatchet. It is flat on one side? Since you want the same angle more or less along the entirety of the bit, it depends on how much material there is to make that angle the same all the way across.
Some of them were made a little thicker in the middle that does end up looking like a “banana grind” when the same angle is applied from heel to toe:
L. & I. J. White
White
True Temper
American Sharpie
Some were made pretty flat.
Hults Bruk
HB.hewing
Plumb
BlckPermaPlumbHew
I could be all wrong on that but it seems that if you wanted a banana looking grind on one that was pretty flat cheeked then you would have to modify the chisel grind in the middle of the bit to achieve it.
Also, sometimes the amount of wear that it has on it might alter what you end up with.
Two cents.
Depending on the premise because I understand the question to be about the profile of the edge and if it ought to be straight or arching. On the face of it there is nothing in the question directly about the bevel shape only its angle. Now if I have the premise correct I'd say, succinctly, straight edge and depending on the edge material and intended use a bevel angle of between 25 and 35 degrees.About as succinct and accurate a reply as you could wish for!
It sucks when you make a definitive statement and are wrong. Haha. But if it's wrong it's wrong! I think the reference to a "banana" shape got me thinking about grind and not edge angle and profile. NOW he has the best answer he could wish for!Depending on the premise because I understand the question to be about the profile of the edge and if it ought to be straight or arching. On the face of it there is nothing in the question directly about the bevel shape only its angle. Now if I have the premise correct I'd say, succinctly, straight edge and depending on the edge material and intended use a bevel angle of between 25 and 35 degrees.
