Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
I've been meaning to post this for a while. The purpose of this thread is to describe how to use super glue to close a wound. We play with sharp knives, this comes up from time to time. Disclaimer: I am not a medical professional. Serious wounds need medical attention. If you fail to clean your wound properly before gluing it up, you can seal in an infection requiring antibiotics and possibly having to reopen it.
Advantages of using superglue include sealing the wound against crud, speeding healing, and areas such as fingers and knuckles benefit from the strong bond where stitches pull out and scar.
I opened up the knuckle on my left hand index finger, cutting into the bone and also opening up the joint a tiny bit. Due to the location on the back and side of my finger it did not continue to bleed badly. The cut wasn't so serious that it would require surgery to reattach anything. I was at home alone so nobody could drive me to the ER. The location of the wound made stitches unappealing. I had recently read up on the use of super glue on wounds and this one was a good fit for it.
Before I go any farther let me say loud and clear, don't dump super glue into your wound. That isn't the way to do it.
Clean the wound thoroughly. I used soap and water and a nylon bristle brush and scrubbed it out under the sink. I used alcohol, opened the wound and worked the alcohol in, pouring about half the bottle in the process. (Man up, go to your happy place, etc). Once the wound is clean the bad part is over. I don't recommend skimping on this part.
Wait until the wound stops bleeding. This might take some time, be patient. Visine ("gets the red out") can help, but really it just takes time. Drink a beer or something.
Close the wound and align the two sides. Any mismatch will stay that way forever (ask me how I know). Apply a bead of super glue over the wound and wait for it to set. Moisture is what sets super glue off, so after a few minutes you can run it under running water to help it finish. The wound is now closed for the next three days (the time required for the super glue to slosh off). Do not put the super glue into the wound. Non medical grade superglue released formaldehyde as it decomposes. This is harmless unless it is up inside your wound, where it will slow healing. Be very careful not the reopen the wound, the patch is very weak at this point.
Cut out a patch of fabric baidaid. Use only the sticky part, don't use the bit with the white gauze. Apply more super glue on and around the wound and glue the bandaid patch down over the wound. Give it some time to setup and finish it by running it under some water. This fabric patch is the key to success.
The patch will hold the wound together from the outside. A deep wound can still separate down inside, so it should be immobilized for a few days. My wound on my knuckle required a simple splint to keep it still for a couple days while it healed. I used a paint stir and electrical tape for a couple days.
I applied a fresh patch a few times, keeping the wound patched for about a week. At that point all that could been seen was a pink line that has since disappeared. I had nicked some connective tissue around the joint when I cut it, so I wasn't able to use the finger for much for a couple weeks while that healed, so the wound looked healed before it was. It took about a month to not ache when I'd pick up a mill vice or something.
Notes:
The idea is to replace stitches. You're forming a patch over the wound with a piece of fabric baidaid tape that will hold it together like stitches.
The patch will fall off on its own in a few days. A deep wound will need a new patch at that time.
The glue must be applied to dry skin, otherwise it will just set off without gluing anything.
Non medical grade super glue should not be used inside a deep wound, put it on top only.
Notes:
