There's no sending it back to a dealer after taking a dremel to it. That knife is his. I'm not even sure the manufacturer should take it back after drilling on it.That's a shame. can you go back to the store you purchased it from? BladeHQ and Knifecenter are usually very good about that amongst many of other retailers on the forum.
No insult taken. I'm not sure who to take it to? A jeweler?If you drilled it out, there would be no threads. He’s talking drill a hole through the middle of the whole pivot assembly and replace the whole thing.
Brhowser87 - no, I don’t think so, from the way OP is describing things. If you can’t get a grip on two screws with two flatheads hard enough to bust it loose, it’s a safe assumption that loosening a scale and mushing it up against “the spinny side” wouldn’t work to hold it steady.
OP - no insult meant here - maybe have somebody who is stronger than you give it a try.
If i did that, then even if I got new hardware from Kizer, it wouldn't work, because if have to cut bigger threads.
Also, i think i may just have to cut my losses, already. This is a lost project.
I'm not sure I have the skill for that, it lets just say I did, for the moment. There's all that Loctite in the threads. How am I going to extract the part still in the threads when it's Loctited to the other side of the pivot? I'll have even less leverage at that point, with needlenose pliers on both sides of the pivot.I dont think you understand what we are sayin . Just drill the center out and the rest of the pivot can be removed with needle nose pliers. You dont touch the threads.
Buy a drill press. Yep, spend a bunch of money to try to repair a $75-$150 knife. I don't think I would have the skill necessary to drill out a pivot without hitting the threads by hand.
I appreciate what you are trying to accomplish. The buy a drill press comment was intended to be more of a joke as I assumed the OP didn't have one. I also buy tools for a single job, but buy good enough ones that will last and be potentially used for many jobs. No criticism intended.I never said buy a drill press, if you dont have one that's a different story. Just offering solutions since nothing else seems to be working. Most Kizers I looked at are about $200. Maybe I just have good taste
Every man should own a vice and drill, but a drill press is a good investment. If he did buy a drill press it's not a one time use tool, it will last 50+ years if properly maintained. I buy tools for one job and then I own them for life, that's just me... I can use for many other jobs later on.
You can criticize if you like but I'm just trying to help the guy. OP If you live close to San diego I'll drill it out for you bud.
At this point in my life, lasting 50 years is not a big interest to me. I am more interested that the power tool works as intended and has some durability. I have bought enough junk power tools over my life to know better.
Believe it or not, about the only need I have for a bench vise is sharpening lawn mower blades. I generally just buy new ones if they are dinged up much. I do own a couple vise's, but do not have a work bench per se any more that I would mount a vise on. That was at my last house and it didn't get moved.
This sounds more difficult than you make it out to be, but like I said, even if you did this, you have the problem of the Loctite binding the bits left to the threads, and now you have even less leverage to free the parts than you had before. I'm open to ideas, but I think this one requires a high degree of skill and is doomed because of the threadlocker, anyway.You would drill out the media in the center of the bolt and the nut then so all that is left is the outside ring of the nut and it would fall free. You just need to size the drill bit properly to extract all the seized parts therefore negating any need for twisting the threads at all.
Imagine you have a 3mm pivot screw and it goes in to a 5mm outsode circumference bolt, you would drill 4mm bit through the center and then the remaining 1mm would be left. If is not threaded to the frame it will fall free. If it is threaded then you use needle nose pliers to extract the remaining 1mm since it will be much easier to work with now. I've done it before many times. Even my 1911 bushings once.
I appreciate the help. I've been looking for an excuse to buy a drill press, actually.I never said buy a drill press, if you dont have one that's a different story. Just offering solutions since nothing else seems to be working. Most Kizers I looked at are about $200. Maybe I just have good taste
