Good axe under $75
Great question, and the bay is a good place to browse, see what's out there.
What would your primary use be?
Have you considered the weight of the axe and length of the handle?
Are you desiring a golden era North American axe?
European?
Modern axes can be found today, made of good quality.
All that said.
The axe i recommend you look for a 3 to 3 1/2lb axe on a 28-32" haft depending on your wing span and primary use.
If your looking for a camping or similar type companion, go smaller head weight...1 3/4lbs - 2 1/2lbs on nothing longer than 28".
Hope this helps narrow your search:thumbsup:
All good advise so far.
If you want to buy off the shelf then have a look at Council tools. If you want something nicer find a vintage American axe with convex cheeks and little wear on the toe, then re-hang it yourself. It will be fun and you'll learn a skill you need anyway to care for your axe.
What will you use this axe for? That will help decide the weight and pattern.
is this axe any good
https://www.ebay.com/itm/Mann-Edge-...581764?hash=item42061fb104:g:51AAAOSwgWtdR3cM
Council tool has pretty good stuff. I also like the rinaldi axes offered by Baryonyx knife co. They're not polled and some people don't like them for that reason, but I prefer them from a weight to performance aspect. The slip-fit design is easier for me to maintain as I am apparently horrible at re-hafting a regular axe.
Getting an good head and putting a handle on it is always an option as well and I have a few I've done that with, with good results, once I get the wedges figured out (again, not great at it).
Buy any old USA made axe you can find at the nearest yard, garage or estate-sale. They are usually $2-$5, the higher price range being for those with a good usable handle. don't worry about the brand because they are all good enough for anyone or anything.
