- Mar 29, 2007
Don't laugh, it held up remarkably well in the glue wars, and I've been playing with it. It's a hell of a lot easier to use in really tiny quantities than multi part epoxies.
I've learned 2 things on scales- (we all already knew about water)
get your fit GOOD. I know, sounds silly to say, but it's important. This is not a void filling glue, no "epoxy rivets"
wet rags and qtips. if you wipe the glue line down with damp rags and damp qtips periodically during the "foaming" phase of drying, you can get a picture perfect glue line right away. I generally wipe it down a few times over a half hour or so, depending on temperature.
on cord wraps- I've tested it for a linen cord (about 1.5mm cord) wrap and on paracord.
The paracord is a mess. if there's ANY gaps you can't get into with rags and qtips, you're screwed. paracord always seems to leave gaps.
The linen cord works fantastic. soak the cord in water, glue up the handle, start wrapping- you can cover finger choils and do odd curves without a hitch. I use a popsicle stick to keep pushing the cord together so that there are no gaps and do lots of wet rag wiping as I go along. I use a tannish brown cord, too. This makes a great base layer for over wraps.
