Graham Forge updates, 7 years in the making
A long time ago, I started building forges with the help of several members of Bladeforums. I learned about the differences between blacksmithing and bladesmithing, and I built my forges for bladesmiths because it was a niche market that no one else, to this day, is properly addressing. Here is the latest version of my continuing progress, the Graham v5.
I don't want to use this subforum as a marketing platform, but I simply want to show how far I've progressed, much like any other 10 year member of shop talk.
I've spent a lot of time researching different refractory. Refractory is measured by it's insulating factor, "thermal conductivity, or TC" which measures how rapidly it transfers heat. Lower is better, and the king of TC is inswool/kaowool. At 1.9 (btu/cubic inch) it's a far cry from raw steel at over 600. Mizzou rates 6-7, Kastolite 4.5, IFB 2.9. I have gone with Plicast LWI 24 which comes in at 3.3, although I use it closer to the Plicast CG rating of 2.6. I dislike wool, because wool is very fragile and needs coated with Satanite, kastolite, Hymoor, etc., although I would prefer Tuffmix. Still, not very efficient, and very time consuming to apply these.
I like Plicast CG because it's fiber re-inforced, insulates as well as IFB, and allows me to use different, stronger shapes than I have in the past. I've built over 2500 forges based off of the shape of bricks (4.5" x 9" x 2.5-3"). Sure, they are better than wool, but I always knew in the back of my mind that they could be better. After all, NC Tool uses vacuum formed panels and they are the top of the line, in my opinion. A friend introduced me to Steve, at the Omaha Plibrico dealer, and everything changed. After a couple hours, and several weeks, I tested casting with Plicast LWI 24. A steep learning curve to be sure, but I'm getting better.
I now cast a fiber re-inforced refractory into a TIG welded stainless shell. This thing is sturdy! I messed up and had to remove the refractory on one, and it took quite about 20 minutes with a hammer and chisel to remove it. Wool could have been removed in about 30 seconds. The refractory takes 24 hours to cure, and about 6 hours in the oven to dry. This is offset by the time it used to take to cut the bricks, and is less than what it takes a customer to coat the wool with refractory.
Casting the entire shell at once also allows me to be more precise with the burner angle. It is cast, with a 1.10" foam insert, at an upward angle at a tangent to the chamber. It swirls perfectly, with a front to back inclination. This provides a complete combustion in the chamber, and very little dragon's breath. Not quite as even as a ribbon burner, but very close. Measuring showed less than 200°F front to rear difference!
A little bit about the new blown burners: I love them, they're awesome. A cheap blower, 12VDC PWM speed controller, and I've created a blown burner with better control than the big Dayton powered systems out there. It's got smooth control from 0-100k BTU through variable fan speed and 20 PSI regulator. Introducing the propane through a perpendicular orifice mixes it very well, in a much shorter tube than previously recommended.
This is my most advanced forge yet:
As I mentioned before, I have one of your prototype hellfire forges with the blower. I love the fact that a new blower is about 10 bucks if it fails on me.
View attachment 1310104 View attachment 1310105
I have to ask just because I have been seeing some interesting stuff on you tube. Have you ever tried any of the homemade starlite recipes from cornstarch baking soda and Elmer's glue? It sounds interesting but its probably not as effective as real refractory.
I think your last forge is about the best knifemaker's forge on the market. It has everything it seems needed for knifemaking with the blown burner that's angled up and rearward for the swirl flame pattern. I don't think there are many more on the market with all those features.
Some really good evolution.
One thing I always tell people about Charles is that he re-thinks whatever he does and makes changes when he sees places to improve. Far too many people create something as decide that it is the best there ever was ... and never try to improve it. Another thing that is noteworthy about Atlas's customer service is when he makes an improvement over a past model, he will often offer the upgrade as a retrofit to earlier models at a reduced cost (or even for free). You rarely see that in other businesses.
One thing I always tell people about JT is that he re-thinks whatever he does and makes changes when he sees places to improve. Far too many people create something as decide that it is the best there ever was ... and never try to improve it. Another thing that is noteworthy about JT's customer service is
Stacy, I agree JT does all those things, and Graham Forges seems to have the same attributes. Great folks both of them (they're not the same folks?).
I still love my little forge and think a Atlas forge is almost a must for any knife maker even if they are mostly stock removal like me. I want to get one of his anvils as well to replace my post anvil. Atlas is one of the best in the knife makers world.
Looks excellent man... I would of bought this one over the one I built in a heartbeat. One stop shop and clean to boot. Cheaper than the one I built too... And obviously better researched and better executed!
Does anybody have this new forge with the blower and any videos of the heat distribution and can offer any review?
