Been using a thin gun oil on my 21 (ran out of the CRK grease) and if it gets on the lock face it causes lock stick.
I have tubs of this stuff at my workplace, but how much thicker is it than CRK grease? To me it seems stickier but I've never had the two side by side.A reco to you and to all, Krytox GPL 205 is great, especially in the applicator syringe w/ the super-fine tip attached. It's NSF H-1 certified (so it's safe for incidental food contact), it feels absolutely perfect, and for about the cost of two 5g CRK fluoro tubes, you'll get a syringe with enough to last the rest of your life even if you cleaned your knives way too often.
The biggest plus (to me, anyway) is that the lubricant doesn't separate, so you won't have one of those "oh crap" moments when you squirt out all your base oil and leave behind a tube of (mostly useless) thickener that costs $10, and takes a few days, to replace.
Since I squirted out my CRK (Christo-Lube) base oil, I can't make a fair comparison. Then again, even if I did have it, I wouldn't trust my own assessment--I'm no tribologist.I have tubs of this stuff at my workplace, but how much thicker is it than CRK grease? To me it seems stickier but I've never had the two side by side.
...so it seems "Nano" is referring to nano oil, and not the nano grease? I've been a little curious about whether the nano oil 85wt outlasts the 10wt, in case you've tried both.I have used Nano, KPL, and CRK grease forever. Must admit the grease works best over a longer period of time between cleanings. I think that the nano works well, but not nearly as well as the grease especially for smoothness.
Chris Reeve always said to use grease & not oil. There is a reason. Oils are meant to lubricate closed systems, like your car engine. Greases are meant to lubricate open systems, like firearms and knives.
Certain greases actually bond chemically with the metal - providing lubrication & protection at the cellular level. Without going into a long discussion, greases are a better choice for pivots. If you want an alternative to CRK grease, try TW25B . It is a light grease preferred by the military for all firearms. It is applied lightly - not gobs of grease- and will lubricate your pivot (or firearm) and for longer periods of time because it provides lubrication and protection both physically and chemically.
if you are curious and want to learn more, research “grease vs oil for 1911 firearm”
