J Lensmire
- Oct 30, 2021
Noob, here. I use 80 then 120 grit ceramic belts when initially grinding my blades. Once that is done, I finish pre-heat treat grind with 120 then 220 Aluminum Oxide belt.
After heat treat, start with 120 Aluminum Oxide to remove scale and if needed, bring blade thickness close to final. I then transition thru 220/440 Silicon Carbide.
I finish all my blades with hand sanding. My question is, after all this, how can I still have what appears to be 80/120 grit marks on blade that appear during hand finish?
this occurs on both A2 and CPM154, currently the two steels I am using.
