Good comments folks - Sorry I've been out of touch, wife had foot surgery yesterday and I've been sorta out of pocket for responding. I've been reading the posts, but I don't do much for typing on tablet or phone, I NEED a real keyboard for typing - just old fashioned I guess {g}
Fitzhugh, that's a really good drawing you did in Fusion 360. Here are a couple of photos of my tracking system. The first photo shows the tracking from front view. The 1/2"X2" wide bar (plate) laying on top is bolted to the tension arm with only one bolt allowing it to pivot in respect to the tension arm. The tracking wheel tab is bolted to the top plate and changes angle as the system is pivoted with the adjustment screw at front. The plate is bolted to the outside vertical bar which is also a 1/2"X2" aluminum bar with two bolts to hold it solid. The spring at rear that holds pressure on the system is shown at rear.
The rear spring shows a bit better in the next photo. The system looks a bit rough, but it works good.
The proper setup is with the tracking wheel axle set exactly perpendicular to the tension arm in all positions. Tracking adjustment is made as the tracking wheel is angled a tad forward or rearward from perpendicular.
I like the idea of a ratcheting tension system but have not came up with design to build one yet that wasn't too complex. AND the spring system I've got seems to be working pretty good. I used a "prop" in place of the spring to test out the ratcheting system and while it worked good, it didn't seem to buy me much. Maybe I need to revisit? I do have to put a pretty heavy spring in place when grinding high speed with ceramic belts because they will "drift" to one side with grinding pressure without heavy belt tension.
Later
Later
