- Aug 8, 2004
Greetings all! A while ago, a grinder kit came on the market. Things happened, and it was no longer available. Then, Chris (aka blindhogg here) redrew a similar design. The cad files can be found at http://blindhogg.com/eerfgrinder.html
We talked a bit, made a few changes, and this is what came of it. I'll be offering this grinder kit for $250 plus shipping ($10.20 in the US via USPS flat rate box.) I can only make it to the post office to ship these on Fridays. I'll have everything boxed up and ready to ship each week. When ordering, please include which platen style you'd prefer (pictured below). I accept credit cards only at this point.
If you want to use a MAP arm it will not work with the current design of this kit. As the kit progresses, there may be a way to use them together.
Here is what is included:
And choice of either platen style. The top one is the multi platen, it uses a small wheel at the top, a large wheel at the bottom and the platen itself inbetween. It can be rotated to use any portion. The bottom one is the standard platen. It's meant to have two smaller wheels with the platen itself inbetween. It can rotate to different angles.
There is a little assembly, drilling, tapping, and countersinking a few holes. Wheels and a motor are not included. It is designed to use a motor with a 56c frame.
The tooling arm mount is 1 1/2 inches as is the work rest. All the pieces are laser cut from 1/2" steel. It assembles to a very sturdy grinder.
My information page for it is located at http://www.polarbearforge.com/grinder_kit.html. The page contains assembly instructions, a tool list, and a couple estimated pricing breakdowns depending on style of platen.
This grinder can be setup to use 72" belts. I setup one of mine with a 60" belt, and the rest will be 90". There's a lot of room for adjustment, it's all dependent on the length of the tooling arm.
I run 90" belts, so I make a mockup of a 72" belt to show the proportions of an assembled grinder.
I have some pictures of completed kits that I'll be adding to my website in the next few days.
I think that's most of the information. If there are any questions, please ask me. Email is the easiest, jamie at polarbearforge dot com. Thanks!
Jamie
Jamie
