- Nov 27, 2013
So I’ve been binge watching Kyle Royers Youtube videos and saw him use a technique in which he grinds on a pommel nut, with a dremel, while it’s spinning in a lathe. This intrigued me and I’m wondering what would be the proper way to go about doing this, safely.
I don’t have a lathe, but I DO have a couple machines that could spin an item. I have a Bridgeport style vertical mill and also a 5-speed Harbor Freight drill press that I don’t really care much about. I know drill presses don’t have bearings in them that would allow it to tolerate lateral pressure on an item spinning in it, but there wouldn’t be much pressure. I was thinking about using the drill press solely for this purpose. I have 2 other drill presses and a mill, so I don’t need it and don’t have a lathe, or other way to spin a pommel nut like Royer does in this video.
He’s grinding on it and contouring the point on the pommel nut at the 10min mark.
I know a lathe has a huge chuck gripping the item being spun, which a drill press chuck pales in comparison to. But as long as I’m only applying a light amount of pressure to the item, would it work? I wouldn’t be hogging off a ton of material. I’d literally be trying to do exactly what Kyle is doing in the video when he makes the point on the pommel nut.
Other than using a method like this, is there anyway to make a pommel nut without a lathe? I can drill, tap, and thread by hand. But it’s turning the shape perfectly round that’s the problem. I could get it pretty close by hand on the grinder, and then finish using the dremel/drill press combo(or similar). I’m thinking, to make the radiused point on the pommel nut like Kyle does in the video, another option might be to chuck it up into a hand drill and grind it against a small wheel on a 2x72.
Or should I just abandon the notion of making pommel nuts until I get a lathe? Lol
If you haven’t subscribed to Kyles YouTube channel, you’re missing out. He does amazing work.
