Tony Mont
- Apr 15, 2018
Good evening my friends!
Since I used to strugle a lot with my guards in the past, I decided to do a small tutorial with every step I take to fit up a guard. This process requires common tools that more likely will exist in a knife shop already.
I will try to keep it short and simple, the complete tutorial will be in three posts due to the 10 image limit per post.
The fit up begins by proper preparation, the tang has to taper in both directions otherwise the guard will not slide.
With the tang ready to accept the guard, it's time to mark our material.
Roughly 25mm-1" wide is enough.
Mark the height of the tang and the center line. I like to scribe my center line deep to make my center punch easier to line up later on.
View attachment 1889454View attachment 1889455
This knife has a 6.5mm-0.255" thick ricasso, therefore I will use a 6mm-0.236" drill bit. Using the drill bit, I mark where I should center punch. The better job you do center punching now, the easier filing will be later on.
Once the holes are drilled, I use a larger drill bit to drill a recess on the back side. A drill bit that is 1.5mm-2mm (0.05"-0.07") larger is plenty enough
Use the depth stop on the drill press to roughly stop 2.5mm-0.10" prior going through. This recess has a double purpose, firstly, it makes the fit up later on much easier (specially on a thicker guard stock). Secondly, once the glue up is done, the recess will fill up with epoxy and create a healthy barrier from moisture/water etc.
Since my main holes were tighly grouped, I couldn't drill a recess on all of them.
To be continued...
To be continued...
