Edge pro, KME or, vector.
Gritomatic has these three guided systems and I can never seem to decide which one is best for me to get. I do need to have diamonds and mostly will sharpen folders.
Is the wicked edge Go any good, are the diamond stones only available through wicked edge?
I’m in the 200$ range if at all possible.
Do you know if the Mad Edge will use Edge Pro stones? Their web site doesn't say it does, so I assume it does not.I would get the Mad Edge it's around the 148 mark I think,also with the Wicked Edge the stone selection will be your biggest problem and also it has limit's as far as how low of an angle you can sharpen at when compared to other guided system's.
I go with the Mad Edge and get a full set of Venev stone in 100% concentration and if you can swing both at the same time get the sharpener to start.
Agree 100% with your comments. Having an EP or other tool doesn't mean learning about edges isn't helpful. The EP will get you creating good edges much sooner than starting with bench stones. A great edge, like the one you're showing, takes a practice and knowledge.There are folks who do great work with any number of tools. And there are even MORE folks who use those exact same tools to do crappy work. I use an Edge Pro Professional, and am quite happy with it. I prefer it over a clamped system, and it allows me to maintain good accuracy. It's not cheap, and my pile of stones is probably more expensive than the Edge Pro itself. The learning curve for the tool itself is pretty quick, but the road to learning about sharpening is never-ending.
TSProf K02 or K03 are what I suggest.
