- Apr 3, 2013
I'm friends with Scott Gunn the owner of Gunny Juice and I knew about his emulsion's for a while before they came out and he was still working out some of the detail's on his emulsion's.
I want to start off by saying that I was given 3 sample's free of charge for review and also because me and Scott do favors for each other back and forth,I told Scott if I reviewed his emulsion's and I didn't like them I would say so and he said that's the way he wanted my review to be.
What's different about this emulsion from other emulsion's that are on the market now,first off the filtering process is much tighter then other emulsion's and so there are less stray big particle's floating around in the emulsion's that slipped threw during the filtering process.This emulsion is also used in the making of medical device's from what I understand and the diamond content is added to Scott's desired amount.
The second and most interesting thing about Gunny Juice is that the diamonds are deionized.
Why is it a big deal that the diamonds are deionized,there is an effect when it comes to any particle that is 1 micron and smaller where the particles clump to together and basically form a a bigger diamond so to speak,when particles are deionized it stop's the diamonds from clumping together resulting in a much better polishing effect.
I tested out the 3 current emulsion's available which are .25 on balsa and .5 and 1 micron on Jende nanocloth strop's.
I also got the chance to try some prototype emulsion of Scott's that is the same fluid but it had half the amount of diamonds and I tried it on Kangaroo leather that was un-sanded and because of the emulsion has deionized water in it as well the emulsion took a few seconds to absorb into the leather,this was not the case with the balsa strop I used and Jende strops which were all brand new.
All I can say is I'm pretty blown away by how well this emulsion works,it really cut and polished fast on my Spyderco Manix 2 in M390 that was sharpened with a Venev 800 grit stone before stropping,I was going for a 100% mirror polish where no scratch's remained just a few scratch's at best.
Right now from Gritomatic and Omaha knife you can buy Gunny Juice in .25 .5 1 micron in 10 15 and 30ml size bottles and in about 30 days or so you will be able to 3 and 6 micron and I'm not sure about 9,I know Scott said 9 micron is going to be added to the line up as well.
The bottles use a vacuum type pump system that works very well and the bottle has no dip tube just a piston in the bottom of the bottle that get's pulled up when you pump it and it comes out in more of a drop and not a mist so there is no over spray and wasting it.
All I can say is once the 3 and 6 micron are released I'm going to be ordering 1 3 and 6 from gritomatic for sure this has impressed me more then any other diamond stropping compound I have ever used.
https://www.gritomatic.com/products/gunny-juice-poly-diamond-emulsion
![qQAwGV0.jpg](https://i.imgur.com/qQAwGV0.jpg)
![MaFSq52.jpg](https://i.imgur.com/MaFSq52.jpg)
