- Jan 4, 1999
Comparative review of Japanese Gyutos
The Japanese gyuto has emerged as the finest example of the culinary chefs knife in the industry. Thanks to harder steel than steels used in Europe and the U.S., gyuto blades are thinner and have more acute bevel angles than chefs knives from other countries. In other words, they are sharper and cut better than chefs knives from other countries. Add to this half bolsters that dont get in the way of the back of the blade and you have significantly easier maintenance than on some of the forged European knives.
But which gyuto is best for you? These knives are available for less than $50 and for more than $300. On average the cook can expect to spend more than $100 for a good quality gyuto. Ive tested a number of the most popular models and have developed some opinions that I will share in this post. Ill rate each knife on a scale of 1 to 5 in the areas of fit and finish, cutting performance and ergonomics. Please understand that these are a single persons observations and opinions. They compare to each other, not to chef knives from other countries. Also note that gyutos arent truly forged. Normally, they are made by blocking out the blade and tang from sheet steel and then forge welding a bolster to the tang. It is just easier for me to call it forged. I have not conducted group tests. Id be interested in your own observations as well. Please email if you agree or disagree with what Ive written here.
Ill start out with my very favorite Japanese gyuto, the 240mm Misono UX-10, and use it as a basis for comparison as we move along through the rest of the knives.
Here are the specifications:
Model Misono UX-10 240mm Gyuto
Blade length 9 ½
Overall length 15
Weight 8 ¾ oz.
Construction blocked
Blade Swedish stainless steel, RC59-60
Handle Resin impregnated laminated ebony scales on a full tang
Other Attached nickel silver bolsters
My first impression of this knife was concern because I noticed immediately that this knife was blocked or stamped instead of being forged like most gyutos. It surprised me that the least expensive form of construction was chosen for a knife this expensive. All my concern went away as I tested the knife. It is blocked so that the manufacturer can use very hard stainless steel. This knife takes and holds an edge as well as the famous traditional Japanese knives made of hagane. When I grasp the blade just in front of the bolster, the knife settles into perfect balance. Its handle is relatively long and has no ergonomic bumps that can sometimes make a knife uncomfortable for me. Fit and finish are flawless. This knife is very well made. It cuts as well as any gyuto and better than some of them. Ive sharpened this blade a couple of times with 2000 and 8000 grit stones and it sharpened up in about two minutes each time. This is with several weeks of hard use between sharpenings. So we have a chef knife with a blade almost as long as that of the 10 chef knife that weighs less than an 8 chef knife. It has a hard blade that takes an acute edge and holds it extremely well. It is perfectly balanced and feels excellent in the hand and in use. It has flawless fit and finish and is, therefore, attractive. What else could you want in a chefs knife? For me, nothing. This knife really does the trick for me and I recommend it without reservation. If I had to give up all my gyutos but one, this would be the one. The price is in the area of $200. My rating:
Fit and Finish 5
Performance 5
Ergonomics 5
Next is a knife with an incredible blade but ergonomics that fail me a little, the Glestain 240mm Chef gyuto.
Model Glestain 240mm Chef gyuto
Blade length 9 ½
Overall length 14 1/2
Weight 9 1/4 oz.
Construction forged
Blade Acuto 440 sub zero quench, RC 58-59
Other Granton blade.
This knife has a blade that is literally covered by kullens. I usually find this to be unwanted decoration in a chef knife because, in my experience, they dont really have much effect on the use of the knife. This is not true of the kullens on the Glestain Chef. They are large and closely spaced so they are functional. They help prevent food from sticking to it. I sliced a block of cheese and found this blade worked as well as a cheese knife.
As much as I like the blade on this knife, I have some reservations about the handle. I tend to grasp chef knives on the blade right in front of the bolster. This is a curved ramped area on the Glestain. When I grip it there, my last two fingers fall on the ergonomic bump on the handle which feels awkward for me. I cant help but think the designers intention was to have the user grasp the knife right on the bolster. That would place my hand, at least, in the correct position on the handle. The handle is also a little short, probably due to a steel pommel at the back of the tang which adds a lot of weight to that area. Actually, the knife is very slightly handle heavy. The balance point is about ¼ behind where I would prefer to have it. It is close enough, though. Put this knifes blade on the Misono tang and handle it might make the perfect gyuto for me. The price is around $200. My rating:
Fit and finish 5
Performance 5
Ergonomics 3
Next up is the attractive 240mm Inox Gyuto from Suisin. Suisin is an innovative knife maker that has created some of the finest stainless steel traditional Japanese knives on the planet. My favorite yanagi is from Suisins Inox Honyaki line. I cant help but like their gyuto as well.
Model Suisin 240mm Inox gyuto
Blade length 9 3/8
Overall length 14 1/4
Weight 7 1/2 oz.
Construction Forged
Blade Unknown chrome moly stainless steel
Handle Resin impregnated laminated hardwood scales on a full tang
This is the race car of my 240mm gyutos. It is light and short compared to the others. It is lighter, in fact, than most 7 santokus made in Europe. I cant tell you about the blade material other than to say that it is typical of Japanese gyutos in terms of hardness, edge retention and bevel angle. It cuts just fine, thank you,. The handle is on the short side for me. It doesnt have the troublesome bump of the Glestain but it feels a little cramped compared to the Misono. My knife is quite attractive because the outer lamination of the wood scales is a light colored, nicely grained layer that makes it stand out. Fit and finish are better than most gyutos in the price range. Balance is right on the money. If you like light, maneuverable chef knives and your hand is small to medium in size, this might be the perfect Gyuto for you. It is priced in the $100 area. It is an excellent value in my opinion. My rating:
Fit and finish 4.5
Performance 4.5
Ergonomics 4
270mm is really too long a chef knife to be comfortable for me. I only have one in that size and it is the Hattori HD, an excellent product.
Model Hattori 270mm HD Gyuto
Blade length 10 5/8
Overall length 16
Weight 10 ¾ oz.
Construction Forged
Blade Sandwich with VG-10 interior and soft forge welded exterior, RC 60-61.
Other Exterior of blade is 63 layer forge welded from soft stainless.
Most people refer to the blade on this knife as Damascus. I dont think it is an accurate term to describe it. The Japanese call it ink pattern because it takes on an appearance similar to dropping ink in water. I call it forge welded because it is indeed two layers of stainless that are forge welded and then folded repeatedly to form the pattern. The blade is downright attractive with its ink pattern and it cuts extremely well thanks to the well honed and hard high tech VG-10 stainless steel in the core of the lamination. This knife will hold an edge right along with any gyuto. The handle is excellent for me. It is large since it needs to balance a long blade and feels very good in the hand. Fit and finish are also excellent. It is a shame to see the vertical grind lines in the beautiful blade but this is visible on any gyuto Ive seen except for the Kai Shun knives. I wont mark it down very far for that. It is somewhat blade heavy but this is not unusual in the longer models. The balance point is about ½ forward of its ideal position. I havent tried the shorter models but I suspect they probably balance perfectly. Perhaps someone can confirm that for me. Price is a little over $200. My rating.
Fit and finish 4.5
Performance 5
Ergonomics 4.5
Now on to the shorter models the 210mm. The best 210 I own is the Kikuichi 210mm gyuto.
Model Kikuichi 210mm V Gold Gyuto
Blade length 8 ¼
Overall length 13 1/4
Weight 6 1/4 oz.
Construction Forged
Blade Unknown steel (probably one of the VG series)
Other blade is laminated with a hard core surrounded by softer stainless steel.
When I want an 8 chef knife, the one I almost always reach for is my Kikuichi. It has a hard sharp blade that holds an edge extremely well. Its handle is ergonomically better than that of any other short chef knife I own. Balance is perfect. The knife is hand forged and not just stamped with a forge welded bolster. It is also hand finished. It reminds one of the hongasumi construction found on professional traditional Japanese knives. This not surprising since the company has been making swords and knives for over 700 years. This knife provides not only the best of traditional craftsmanship but performance second to none in an 8 chef knife. Price is in the area of $160. My rating:
Fit and finish 5
Performance 5
Ergonomics 5
Heres the best value in the industry and I mean it. It is the Tojiro Honwarikomi gyuto.
Model Tojiro Honwarikomi Gyuto
Blade length 8 ¼
Weight 6 oz.
Construction Forged
Blade Unknown laminated stainless steel
What can you buy for $60? You can by a knife that is dimensionally the same as the outstanding Kikuichi that will perform as well as most other gyutos that cost more. Hows that for value? If you compare it to the Kikuichi you give up hand forging and hand finishing and the flawless fit and finish. But not much else. Balance is perfect, handle ergonomics are the same as the Kikuichi and, while it may not hold an edge quite as well, it is in line with the rest of the Japanese gyutos and all for a price that is way, way below the competition. You simply cant go wrong with one of these in your knife block. I recommend it to everyone starting out with Japanese knives. My rating:
Fit and finish 3.5
Performance 4.5
Ergonomics 5
Ah yes, the famous Global G2 from Yoshikin. Is it a gyuto? I dont know why not. It doesnt have the typical gyuto shaped blade but neither do the Kai Shun knives. This is a knife made in Japan for a Western Audience.
Model Global G2 8 Chef Knife
Blade length 8
Overall length 12 3/4
Weight 5 1/2 oz.
Construction sintered
Blade Unknown stainless steel, RC 57-58
Handle Hollow ergonomic stainless steel
This is the sports car of chef knives. It is light and maneuverable. The manufacturer fills the hollow handle with the right amount of sand so this knife, like all Globals enjoys perfect balance. Despite the ergonomic handle this knife doesnt feel quite so good to me as some of the full tang gyutos mentioned above. The blade steel isnt quite as hard as that found on other gyutos but it is hard enough to maintain a 15 degree bevel reliably. I know because mine has had a 15 degree bevel from day one. Its price is around $85 and it will outperform any chefs knife made in Europe. My rating:
Fit and Finish 4.5
Performance 4
Ergonomics 4.5
Blade length 9 ½
Overall length 15
Weight 8 ¾ oz.
Fit and Finish 5
Performance 5
Ergonomics 5
Blade length 9 ½
Weight 9 1/4 oz.
Construction forged
Fit and finish 5
Performance 5
Ergonomics 3
Blade length 9 3/8
Weight 7 1/2 oz.
Construction Forged
Fit and finish 4.5
Performance 4.5
Ergonomics 4
Blade length 10 5/8
Overall length 16
Weight 10 ¾ oz.
Construction Forged
Fit and finish 4.5
Performance 5
Ergonomics 4.5
Blade length 8 ¼
Weight 6 1/4 oz.
Construction Forged
Fit and finish 5
Performance 5
Ergonomics 5
Blade length 8 ¼
Weight 6 oz.
Construction Forged
Fit and finish 3.5
Performance 4.5
Ergonomics 5
Blade length 8
Weight 5 1/2 oz.
Fit and Finish 4.5
Performance 4
Ergonomics 4.5
