- Dec 7, 2016
I have tried multiple times to get my edges hair-whittling sharp, with no luck. I am hoping someone can offer me some guidance.
I want to get a hair-whittling edge just for fun. I have no practical need for such an edge beyond personal satisfaction.
I have worked with a few different types of steels, the latest three were S35V, Elmax, and M390. I can get each edge super sharp, but can't whittle hair.
I use a Buck Honemaster sharpening guide. I know it is old school and there are much fancier sharpening guides available, but the Honemaster works perfectly well for the one angle it is set to.
I check the bevel with a 20x loupe as I progress. With the loupe, I can see the scratch pattern being successfully refined at each step.
I start with a progression of DMT diamond hones. I use the hones dry. If I am setting a new bevel, I use the XX Coarse hone, which DMT lists as 120 mesh equivalent. I then progress through all the DMT diamond hones, raising a burr on each side of the blade before moving to the next stone. I end the DMT progression at Extra Extra Fine, which DMT lists as 8000 mesh, or 3 micron, equivalent. I should note that once the edge bevel is set on the XX Coarse diamond hone, I can raise a burr on the subsequent hones pretty quickly, say 10 - 20 strokes per side. This is true even for M4 and CPM 10V steels. I interpret this to mean the hones are cutting quickly and the Honemaster is accurately holding a constant angle.
Next, I hone the edge with a Spyderco Ultra Fine ceramic stone, which is generally accepted to be about 3 micron equivalent, but it does refine the edge beyond the DMT EEF hone. On the ceramic stone, I use a mixture of water and liquid dish soap to minimize clogging the stone. Again, I raise a burr on both sides with this ceramic stone. Being ceramic instead of diamond, it takes a little longer to raise a burr.
After the ceramic stone, I strop the blade on flattened basswood strops using DMT diamond paste. I use a trailing-edge motion and go slow with light pressure. Grit progression is 6 micron, then 3 micron, then 1 micron. Again, I check the progression with a 20x loupe, and can see the scratch pattern continually being refined at each step. I have 0.5 micron DMT diamond spray, but I haven't used it, yet. Seems to me I should be able to whittle hair with an edge stropped on 1 micron diamond grit, if I am doing things correctly.
So, after all this sharpening, I borrow a hair from my girlfriend (cue the eye-rolls), and damn I can't whittle it. I've tried moving the blade in both directions along the hair, and at different angles, but no luck. The blade is so sharp it practically reaches out and grabs the skin on my thumb, but it won't whittle hair. Again, I am doing this just for fun, but, still, I would like to be able to achieve hair-whittling sharpness.
Anyone got any suggestions on what I may be doing wrong?
TIA!
Part of whittling a hair is realizing itnis abit of a parlour trick. You have to whittle from the tip ofnthe hair towards the root. This is because of the way the scales that cover a hair overlap eachother. Whittling towards the root lets the edge catch on these scales between where they overlap.
In this picture the root is towards the bottom. See how trying to whittle in the direction towards the tip won’t let you catch those overlaps.
