- Dec 20, 2005
Hi,
I just made a really thinly ground slicer out of 1095. Can I create a hamon on this with satanite? Or due to the thin grind am I likely to crack the blade?
I heard water is the best at producing hamons, but is 1095 prone to cracking in it? Is there anyway to use water safely? eg. Interrupted quench? Quenching only the cutting edge? Combination of both? Normalize several times prior to quenching?
Or should I just use tranmission fluid?
Which one produces the most vivid patterns?
Thanks!
Thanks!
