I'm also in the 'simpler is better' camp where sharpening equipment is concerned. Sharpening by hand with bench stones or handheld stones is a learned skill like any other. If you learn well, it can be just as reliable and effective as sharpening with a guided system and it'll be with you for life - it becomes muscle memory and automatic with repetition. And it can be much, much less expensive to do, once it's learned. You don't need elaborate, expensive systems to do it well, and you can produce excellent results on modestly priced stones of decent quality. But it's perfectly OK if you're not comfortable with that and prefer to use a guided rig for awhile, or indefinitely, if or until you choose to pursue sharpening by hand.
I used a guided system for some time, which helped me learn the fundamentals of how an edge is made sharp to begin with. Once that was clear in my mind, I gradually started doing some of my light touchup sharpening on handheld stones, just maintaining the apex crispness without focusing too much on completely regrinding bevels, which is more demanding of technique, i.e., holding a steady angle for many, many passes on the stone. Once I became comfortable with the light touchup sharpening done by hand, I started using bench stones for complete regrinding of bevels. And since then, I've done everything by hand and have not looked back. It's all a process learned over time and with patience.
I will agree with the earlier comment about the pull-through sharpeners though. So many of them are made to be 'simple to use' in concept and they're very popular for that reason alone. But the way they work, by scraping steel from the edge in a direction parallel to the edge, instead of perpendicular to it, will leave the 'sharp' edge torn, very weak & flimsy without very, very frequent resharpening, which drastically shortens the edge's useful life. They're not good at all, for making sharp edges that will also be strong & durable. Literally any other means of sharpening would be better for the sake of the knife's longevity.
