FortyTwoBlades,
When I am out in the Forest or up in the mountains I of cause maintain my edges by freehand, I do not carry a 3 kilo sharpening tool with me. I did not think I needed to explain that.
When I am home - i use my tool. This becouse that I am lazy. My tool stand on a bench and are ready to use all the time. If not, it do not take many seconds to put it up becose of its construction.
as Inweote above, 1 degree change on the cutting edge add, or take away, less then 1/1000 part if 1 degree if the material innthe edge, we wobble at least 3 degrees when we sharpen by freehand. If I take away material from the cutting edge - I must remove material from the complete edge ro correct what I remove from the edge - or accept that my edge do not have the same angle along the edge...
For me it is simple. If I do not know what edge angle my knife have - and I change the edge angle, I do not know where I started, I do not know where I Landed and I so not know how long I have traveled - and what can I learn from not knowing what I just have done?
When I know where I started and landed I also know how long I have traveled - and knowing what I have just hade done makes that I can evaluate what I have done - and from that can I learn, and that learning adds up with other things I have learn before.
For example can I learn how a edge in 20 degrees total works compare with a edge in 22 degrees total - and if I work in the same material I can understand the differance how the different edges work in the material and how much power I need to use and how much the edges warns - and from that can I also learn.
Most people have not a clue whatvedge angle their knifes have. They are happy when they have learn to grind the edge so thatvthe edge two sides meet eachother so that the edge become sharp - and they dont have a chance to compare edge angles, power in use,mhon the edge warns ir how fast the edge gets dull in different materials. The egde just gets dull - so they grind the two sides together again.
There is a lot more about shatpening that just know to how to get the two sides of the edge to meet properly, at least in my mind.
For me shall a knife be as sharp it need to be for its purpouse, not sharper, or duller, then that. But that is me. I have absolutley no demands that other people shall have the same opinion as me.
It is a simple sentence - it tells that sharpness must allways be balanced with retention. That is also why we have scalpells and razors - and shoemaker knifes, they are different levell of sharpness, balanced with needed retention + the blade design are made to make the work as easy as possible.
If the sergent change knife with the shoemaker - both will have. Hell to do their jobs.
So, if I have a good hunting knife and I sharpen the hunting knife so that I can shave with it - I have change the knifes purpouse, the hunting knife have become a razor - and it is now to sharp to be a hunting knife. This is old traditional knife knowing and understanding here in Scandinavia, known by most traditional knife users = about 5-10 % of the population here. 90% of the population lives in citys and have not a clue about traditional knife use
Traditionals here use edges between 18-26 degrees. Citypeople use edges in about 35-40 degrees becouse they cut and slice in plastic, nylon, cardboard, det hard wood, and so on = typical city magerials.
Traditionals cut and slice in wet fresh wood, leather, huds, fresh meat, fresh fish, and ao on - and can use lower edge angles. They have 35 degree edges on their axes.
This is a normal development for knifes,ntheur design and edges comes from needs. City material are harder= city edges are steeper = balance between sharpness and retention...
I live out in the Forest with many miles of Forest around my house - and my knifes are traditional knifes with traditional edges. My chopping knife has convex edge in 26 degree total - and are used in fresh wet wood only. My axes hold 35 degrees and are used innthe same material. My carpenter axes have flat edges and have 18-24 degree edges (different axes). I use the axe, or knife, that is best for what I shall do.
From this I write and speak. I like to spread old traditional knife knowledge to them that are interested. Here I have explain that sharpening tools are at least 6000 years old and that they have developed duringvthe millenians - most free hand people do not know this becouse they think that they do not wobble at all
Go baxk 10 years and read in this forums member then say that they did not wobble and that convex edges was superial and better then all other edge types
There is more knowledge and less myths today.
Thomas
