handle removal from ww2 bolo knife
hi all, hoping someone can help, I have acquired a ww2 martindale bolo knife, it's a lovely blade by the handle is quite blocky bakalite I think and I am considering removing it and replacing. I would like to preserve the brass (I think) pins and reutilise them. I can photograph, just curious if anyone has experience with this kind of refurbishment.
tia
adz
tia
adz
Welcome to Bladeforums Adz.
A lot of people here have experience replacing handles. It's not an uncommon modification.
If the pins have been peened (the ends hammered to spread them out) then I would be surprised if you could reuse them. When pins are peened they often get a bit deformed along their length. But you shouldn't have any difficulty making new pins out of commonly available brass rod. Or you might decide to use a different form of fastener, there are a variety of options.
I have to ask, have you considered or researched if that machete has any collector value (worth more than you realize)? Due to your membership level you're not permitted to ask for value estimates here, but it might be something you want to check on before modifying it. Of course it's your machete and you can do whatever you want with it. I just thought I'd mention it. :)
it has little intrinsic value, I have checked, it only cost me a few quid, I have checked thanks gents. the handle is in pretty bad shape, hence the replacement, but I will bear that in mind. on another topic, the pins are brass I assume and have discoloured green. any tops on how to go about restoring them to their original shiny glory
Pick or rub off the heavy verdigris with a pin or rough cloth. Then rub them with tooth paste or vinegar mixed with baking soda. Alternatively, any kitchen cleaner should get it off. Verdigris isn't tough as far as corrosion goes, but it is persistent.
I have restored a few antiques over the years, some for myself and some for other people. I do frown upon melting antiques down like some YouTubers do, and destroying old blades and forging them into new modern knives. I don't consider handle replacement of a broken or decayed handle destructive, in my opinion (Some people disagree) it would be a type of preservation and restoration. The same way removing active rust is helping the blade and not harming it.
I would also replace the handle, especially if water can get inside it because of the damage, you don't want wet rotting material touching the blade tang and eating away at it, that might lead to it completely breaking and pitting to the point of no return.
I also believe that it's okay to responsibly use antiques, I have restored and cut with antique swords that are hundreds of years old. I have a British 1845 officers military sabre that I restored and still use to test cut with.
I also have a collection of antique hammers that an old blacksmith sold me when he retired, they were older than him, and I use them to this day, especially the small ball peen hammer I use that to set rivets all the time.
I think you might need to replace the handle pins, it's possible you could hammer them out and try and salvage them, but I think you will most likely need to put new pins in. You can buy brass rod on ebay at any thickness and length. I buy all of my brass rod on ebay for handle pins and rivets. Just measure the tang holes and buy some brass rod. You can grab some Micarta and wood scales from ebay as well for a good price and restore it for a low price. Making handles is actually pretty easy, you can do the whole thing with just an angle grinder flap disc, or set of hand files, expensive equipment not needed.
thanks for that, thoroughly informative. much obliged
I’m not a knife restoration expert, but I doubt you’ll be able to save the pins. Break the handles to expose the pins and then cut the pins to remove the peened area and slide the pins out.
