Recommendation? Handle scale removal
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by Travis Talboys, Aug 1, 2019.
  1. Travis Talboys
    Travis Talboys
    35
    Oct 30, 2018
    I have this knife that I am unhappy with the handle, and I was wondering if there is an easy way to remove epoxied scales without ruining the blade. The material is alumilite with fiber liners, with SS pins. Any help here would be greatly appreciated.
    Thanks,
    Travis
  2. E.Carlson
    E.Carlson KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    733
    Mar 28, 2016
    Drill out the pins (if you can grind both sides of the scales flat, it will be easier). Use a heat gun to heat up the tang until the epoxy gives. You should be able to pop the scales off with a knife.
    john april likes this.
  3. milkbaby
    milkbaby
    585
    Aug 1, 2016
    If you drill out the pins, make sure to absolutely cover up the blade and clamp the knife so it won't move, preferably in a drill press vise. Nothing as fun as a whirling blade of death when you don't expect it (though you really should've).
  4. daizee
    daizee KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Dec 30, 2009
    Heat the whole knife to 250F, then drive the pins out with a punch, and peel off the scales.
    razor-edge-knives likes this.
  5. Matt Rochester
    Matt Rochester
    Nov 28, 2014
    If it’s quick setting epoxy you can drill the pins, wrap the blade, hold the knife by the blade and smack the handle on bench top. They should pop off. Once I switched to g-flex this handle removal process didn’t work anymore.
  6. Stacy E. Apelt - Bladesmith
    Stacy E. Apelt - Bladesmith ilmarinen - MODERATOR Moderator Knifemaker / Craftsman / Service Provider
    Aug 20, 2004
    put it in the oven at 250F and heat for 30 minutes. It will smell a bit, BTW. When you take it out you can pry the scales off, or punch the rivets out and pry them off.
  7. Gilbert M
    Gilbert M
    94
    Sep 8, 2013
    I just use a bandsaw tape off the blade. Grind off the little bit left ,switch to finer grits for final clean up.
Share This Page
