One of a Kind Damascus Knives by Gaston J. Glock
OFFERS ACCEPTED! Please reach out with any offers or additional questions. More pictures available upon request.
Gaston J. Glock Old Style of 1932 Tirpitz Pocket Knife - $549
- The knife model is manufactured based off the drawings and sample books of 1932
- The body of the knife (skeleton) is composed of two stamped brass liners, each having welded pins made of nickel silver, a back spring, a guard attached to the back spring, a connecting piece as well as a blade.
- The part resulting from “liners” and “pins” is characterized as a “booklet”
- The blade is made of 320-layer non-stainless Damascus using recycled steel from the German battleship Tirpitz – the wreck was salvaged by a Norwegian and German company.
- A renown blacksmith folded the steel using traditional handcraft
- All of the parts are permanently riveted together – this pocket knife's production method is comparable to that of how the knife was assembled in 1932.
- The knife's scales are made of mammoth tooth, a very fine and sensitive material, thinly sliced and difficult to handle during assembly.
- The scales are carefully attached to the knife's skeleton
- All of the approximately 100 different steps are real handcraft performed by highly skilled professionals
- Information:
- Total Length: 6 inches (152 mm)
- Blade Length: 2.5 inches (63 mm)
- Blade Strength: 0.08 inches (2 mm)
- Hardness: 61 – 63 HRC
- Pattern: Wild Damascus
Gaston J. Glock Old Style of 1932 G3 Pocket Knife - $729
- This knife model was made based on drawings from the manufacturer's pattern books from the year 1932.
- The body of the knife (skeleton) is composed of two stamped brass liners each having a welded nickel silver liner, a back spring, a guard attached to the back spring, a connecting piece as well as a blade made of G3 Damascus steel.
- The part resulting from “liners” and “pins” is characterized as a “booklet.”
- The Damascus steel used for the blade – from an old G3 assault rifle – makes this pocket knife exquisite and unique.
- The unlocking of the fixed blade occurs via a sophisticated mechanism, which is triggered by the guard – made of the material nickel silver.
- To manufacture the knife's body, the parts are permanently riveted together. This pocket knife's production method is comparable to that of how the knife was assembled in 1932.
- The knife's scales are made of stabilized bog oak – a wood which has been preserved through thousands of years in Danish bogs - the color changing to dark brown through the aging process.
- The wooden scales are carefully attached to the knife's skeleton using nickel silver pins and then permanently riveted together.
- After more than 100 separate steps using high-quality materials, highly skilled professionals created an extremely durable, top grade knife which retains its sharpness.
- Technical Information:
- Total Length: 8.75 inches (223 mm)
- Blade Length: 3.75 inches (95 mm)
- Blade Strength: 0.09 inches (2.3 mm)
- Hardness: 58 – 61 HRC
- Pattern: wave Damascus
