Does hard chrome plating allow rust to build up under the coating?
I found these post about it:
Does this mean hard chrome isn't good for a high carbon steel?
And as Mad Dog found out...the bare steel exposed edge allowed rust to form UNDER the HC and blade failure from cracking was a possibility...
The rust thing under hard chromium is a geometry effect rather than galvanic corrosion (Chromium is the more active metal, but only slightly, and the small beneficial potential difference can be overcome by the reaction kinetics) The nature of the chromium plate, especially when compromised, allows differential oxygenation corrosion (crevice corrosion or filligree corrosion -creeping fingers of rust) to operate along the microcrack between the steel and the chrome plate. This isn't driven by the chrome or the steel, but by atmospheric moisture and differences in the available oxygen at the tip of the advancing corrosion reaction.
Paradoxically, neither a more porous coating, nor a more strongly bonded perfectly impermeable one, would be so susceptible.
