I'm a noob knifemaker, a bit over a year now, and have been baffled-to-irritated by the lack of reasonably affordable ways to test hardness, in the gap between $120 file sets and a $3k Rockwell penetrometer.
Ray Rogers has invented a rather ingenious penetrometer-type device that's clearly accurate - but it takes rather a lot of time and welding etc. After some reading up, I'm pretty sure the WWII-era sclerometer - aka 'how high does a ball bearing bounce off it compared to known samples?' - approach has a lot of merit. Hell, after buying just the 55 and 60 files, I'd probably be real happy with a set of those suckers if they were two HRC points apart and just in my range, instead of $120 for 6 files that go from 40 to 65. (Hmm....venture idea...anyone know how to make files...? >
There's always a clever hack. I don't need NIST-traceable results, just a good comfort level that I'm within a couple of points of what I need. If I can just compare my readings to a few reference blocks - which again, need not be blessed by Swiss elves in a seismically isolated cavern - I'm happy. Look: I make chef knives (including lately for some Michelin-listed folks), not collectors who're gonna take micrometers and loupes to 'em - I work the heat-treat (which I do, as well as vacuum-stabilize and everything else, myself) to the purpose and the customer preference, but everything I do is Japanese-style so fairly hard. I just need to know whether I'm hitting from say 57 to 63, depending, and where in that range.
(Given that the classic Mohs scale relies on just plain-ol' scratching, with a set of reference hardness substances, I'm curious as to why we need penetration as the standard method. I get it if you're differentially hardening or doing combo-metals, and don't like scratching your blades, but (a) I can test my tang and (b) I can test my blade before I do the final grind. What about just a set of "scratchers" - they don't have to be files, you could just sharpen 'em as needed and periodically verify on a set of known test blocks? It shouldn't be hard (sorry!) to crank out, HT, and test a whole bunch of pointy-sticks and blocks, right?)
Again - there's GOT to be a good hack that doesn't take a ton of money or time. Would love thoughts!
