- Jan 27, 2006
I'm starting this thread as a warning to many, who may very well have this crap slowly invading their land, and will eventually take over everything. Even TREES are no match for the mighty stranglehold of it's woody vines!
If you want a valid reason to own SEVERAL Axes, Hatchets, Machete's, Khukri, Knives, and Saws,......then THIS plant is the reason you can use to explain the cash outlays for all the above,.... to the "misses"!
And I'm sure I'm not alone in finding the dreaded "Kudzo" vine a real PITA to keep in check. What the hell were the gooberment leaders thinking by allowing this crap to come in from Asia, as an "ornamental plant" to shade porches no less! That's what TREES are for!
http://en.wikipedia.org/wiki/Kudzu_in_the_United_States
QUOTE from above link, and worth reading entirely:
"The kudzu plant was introduced to the United States in 1876 at the Centennial Exposition in Philadelphia.[5][6][12] Kudzu was introduced to the Southeast in 1883 at the New Orleans Exposition. The vine was widely marketed in the Southeast as an ornamental plant to be used to shade porches,...."
I was out today, AGAIN, slowly working my way thru this crap, and I was literally shocked at the strength and stranglehold the Kudzo can exert on just about everything else growing in your yard. Last year I removed a LOT of vines from a Pine tree in front, and a few other trees that were struggling. The Kudzo not only grabs a tight hold on your trees and bushes, it's plentiful leaf structure also blocks out the sun the other plants need to grow and remain healthy.
I noticed one maple tree was already dead this year, and I cut it down today with a hatchet. But I was literally aghast when I came across another tree that has been attacked,....over what I suspect has been a few years and I just missed it. (buried behind the leafy growth of you guessed it,....even MORE Kudzu!
One limb in particular of this smaller tree (about 10" diameter), had a limb at about neck high, that clearly shows why the Kudzu is so dangerous! Once the vines wrap around your tree branches, It literally prevents the tree from growing normally. I was AMAZED!!!
You would think a growing tree could break the stranglehold of the vines, but that simply doesn't happen. The Kudzu is the winner and undisputed champion!
After cutting out this lower branch, I decided to save it as a warning to myself to keep up the fight. With a great deal of difficulty I started to unwrap the Kudzu, to show how deep the vines can get within a branch. This tree branch literally had to grow AROUND the Kudzo.
Some pictures:
This tree limb is about 1-1/2 inches in diameter, and the Kudzu reached a depth of about HALF of that,.....Unreal!
This stuff is the plant version of a powerful Boa Constrictor, whose clamping power belies it's relatively modest size.
This is the limb right after I cut it out, showing the regular and complete "wrapping" this vine is known for.
.......and after a short section of Kudzu was unwrapped to take the previous depth of damage close up pictures. (on the back side of the limb here, so not visible in this photo)
Look at how DEEP the Kudzu has worked within the tree limb,....Unreal!
Here's one of many bushes that have been overrun with this crap,....will get started on it later today:
....and a few more problem areas:
Some pictures:
