Hawkbill blade question ...
I'm looking into transitioning to a Hawkbill blade for EDC/SD and have a question about current available models. I read that the Civilian is a dedicated SD knife and not recommended for other uses, thus I have compiled the following for consideration: Matriarch; Harpy; Spyderhawk; Tasman; Dragonfly. I also found the SPOT neck knife from some years ago on the secondary market, but prices are quite high. My question: does one of the listed models excel as a dual purpose EDC/SD knife over the others? My EDC duties are not especially strenuous, and I will use the new knife for SD training and carry.
Note: The CS Black Talon is a bit too large for my tastes, and isn't a contender.
Thank you in advance for any advice, information, recommendations.
Thank you, Doc ... Much obliged. I also saw your earlier thread on the Spyderhawk. Looks great!
One you didn't mention is the Byrd Meadowlark Hawkbill. Nice inexpensive option if you just want to see how a hawkbill works for you in that role. It's a good edc size with nice ergos for my hands. I'm glad to have it, but tend to only pull it out for specific tasks, like yardwork. I've stuck with regular PE knives for edc. Can't really comment on how it would work for SD.
One of my first spydercos years ago was a Harpy, its got a Delica feel and size but with a razor sharp serrated hawkbill for a blade. I think its exceptional for self defense blade wise although the handle wont be as grippy as an FRN, it will be more durable when it comes to blade torque during inevitable hard use.
I like the Tasmans as well, I like knowing I can get soaked and not have to worry about blade care, and the serrated blades are still razor sharp, they will just dull quicker than other steels since its H1.
The Dragonfly Salt is a greak hawkbill as well, its smaller than I prefer but a great if thats all you have or are size restricted. I dont really prefer the hawkbills that are larger than Delica size for SD.
For blades that I intend as self defense blades---thats their only purpose so they stay sharp and ready, I carry a second blade for a using blade.
Hawkbills are good for other stuff than just SD, but it is a unique feature for that role to be sure.
I like the Tasmans as well, I like knowing I can get soaked and not have to worry about blade care, and the serrated blades are still razor sharp, they will just dull quicker than other steels since its H1...
To clarify, plain edge H1 is known to not have great edge retention, but SE H1 is widely regarded as excellent. Assumed the OP is interested in serrated hawkbills, but they do make plain edge models too. (Actually reminds me that the plain edge Lil Matriarch Bento Box exclusive in VG10 is still available, cool blade.)
Quote from Sal last year:
Hi Mora,
H1 is not heat treated in the traditional way. The steel is work hardened in the manufacturing and processing of blades. Edge retention in the plain edge config would be about the steels that you listed. It does sharpen easily, and gets very sharp. In the serrated config, it will stay sharper longer than anything we've tested to date.
sal
A waved sd/edc knife is a topic I am kind of passionate about. So please read my long post.
The matriarch is essentially a mini civillian.
That said if it is a knife for dual edc/sd purpose the wave feature is an absolute must. Also I recommend you set it up for reverse wave as it puts the knife in a better grip upon drawing. More on reverse waving below. You have to practice waving until it is second nature. In a self defense scenario it is vital you get the blade out as fast as possible.
There are currently 3 Spydercos featuring a hawkbill blade and a wave feature.
1: the waved matriatch. This and the civillian were designed for people who don’t have much knife fighting training. The idea is you just slash wildly with the blade. Here’s the issue the system is designed for forward grip use. Slashing in reverse grip is not necessarily intuitive without training. This means this knife is not an ideal candidate for reverse waving. That means you will probably be regular waving this knife which draws the knife in a weak awkward pinch grip. I would also recommend you get the Wisemen Signet ring so you can securely regular wave this knife by putting your pinky through the ring.
2: spyderco karahawk: this knife is ideal for reverse waving and actually comes set up for a right handed person to reverse wave. However karambit requires alot of training to be proficient in and is supposedly truly used in reverse grip. That said you can always set it up to regular wave into forward grip and your pinky going through the ring at the butt helps eliminate regular wavings weak draw grip issue. In forward grip it is more intuitive to use with no training as you can slash with it easily.
3: Spyderco P’kal: my personal favourite and imho the greatest self defense folder ever invented. It will be abit awkward to hold normally for forward grip cutting but actually I don’t find it uncomfortable to use for edc tasks. The knife is designed to use reverse grip edge in or forward grip edge in. Because of this it has an excellent draw from reverse wave into reverse grip edge in. It has a system that is easy to learn. Just search youtube videos on Southnarc, Craig Douglas RGEI. It has a very robust self defense system that can easily be learned from watching videos. Also it has the peg wave which is the most reliable wave hands down. Also it has the least extreme hawkbill of the three so that can be good for edc use. There are actually some very comfortable grips to hold the pikal edge forward for edc use. It will just be abit different from other knives.
Ok now onto reverse waving. First of all whichever wave technique you use it is important to practice until you can wave in your sleep. With practice I can reverse wave a knife faster than I can draw an in waist band fixed blade since for the fixed blade I have to lift my shirt to access the handle. Regular waving has you draw the knife sort of behind you meaning it can be prevented by your back being to a wall or if you are sitting or lying on your back. Not so with reverse waving which can be done in almost no space at all.
So what is reverse waving? Here is a picture of me reverse waving my Spyderco pikal. I am left handed but for a right handed person they would move the clip to what is normally considered the “left hand tip up” position of the knife and carry the knife in their right pocket.
As you can see the wave is catching and opening the blade but the knife is opening into a reverse grip. The draw is infront of you rather than behind you so it can be done in less space.
Here is a video of a karambit being reverse waved. The difference with the pikal is that rather than pulling on the ring you draw as in the pic above then when you close your hand into a fist the knife will sort of roll into reverse grip edge in.
Whatever you chose the most important thing is you train with it. Atleast watch some videos online that do demonstrations. Of these knives the pikal’s fighting system is easiest to teach through videos and is no nonsense. If you choose karambit please avoid those techniques where they tell you to flip the knife out of your hand and hold it with only your index finger.
This grip, avoid it plz.
Thank you for responses ... very much obliged! Lapedog ... Thank you also for the detailed write-up, and the P'Kal recommendation. I had not considered that model, but will do so now.
You probably would be hard pressed to find a bigger Hawkbill fan than "your's truly" :cool: Unless it would be the esteemed Dr. Hannibal Lecter M.D. who I haven't seen post here at BF in quite some time. He's even a huge fan of the plain edged Hawkbills and I'm leaning away from PE Hawkbills because I find that the Spyderedged ( serrated) versions to be much more able for extremely rough cutting jobs.
But as far as a Hawkbill for your main EDC I think you might be a bit disappointed in some ways. Because for the past 10 years or so I've been using my Spyderco SE Hawkbill blades as a mere "Companion" blade. In other words I use a serrated Hawkbill for cutting jobs that my main, plain edged EDC doesn't do very well. But to have a fully serrated blade ( especially a Hawkbill) to go with a high quality plain edged blade is truly like having the "Best Of Both Worlds) in the Spyder Kingdom.
If not a dedicated SD blade I'd steer away from the Matriarch. My vote is for the Harpy. Simple and robust with the classic hawkbill shape perfect for EDC and SD.
I agree. Plus the Harpy blade is shorter than 3" and has a specific non-weapon purpose. Both of those two things makes it illegal in more restrictive jurisdictions.
I carry a Harpy, P'Kal and Matriarch. The P'Kal I keep just of self-defense, the edge is "virgin." It's handle is very conducive to routine cutting. Same with the Matriarch. I carry the Matriarch and P'Kal partnered with a slipjoint.
However my Harpy does everything I care to cut. It may not be the best for paring an apple (serrations and curved blade is not optimal) but it still gets the job done. It's a good compromise for self defense and every day chores. It fits the hand well.
I guess you could put the Matriarch and the Civilian models in the Hawkbill group. However both of those models are Reverse S blade designs and really have a completely different set of functions. Because Spyderco has really made the Matriarch and Civilian both to be primarily self defense blades and they originally intended for those models to be for law enforcement and military uses.
Now personally I think those models could be made to be utility knives but they would have to be beefed up. For a long time I've petitioned Spyderco to make the Matriarch with a much thicker blade and also a G-10 handle. I would really love a rigid, bulky version of the Matriarch with a better handle.
You can also put the Dodo and Cricket models in the Reverse S blade slot as well.
