The first thing that came to my mind was that you'd go from overheating the blade to overheating the motor. It's an easy explanation for motors with fans attached- you won't be pulling enough air through the motor to keep it cool, but the actual reason that more heat is generated at low RPMs probably has to do with efficiency curves and motors only being designed to run within a certain window of speeds!The problem with bench grinders is that they overheat the blades. What about of using the grinders at a very slow speed similar to the hand sharpening speed so the steel will stay cool?
............waxes and buffing compound work best on buffing wheels for finish, but not well when trying to sharpen.
if I place a silicon dental dam barrier between the grinder n motor assembly. Grinder assembly is casting and all parts attached can be cleaned and lubed / maintained appropriately.
