- Nov 21, 2016
I was recently commissioned to do 6 straight razors for wedding party gifts. These are going to be my first straight razors and the only steel I had that was thick enough to get a good hollow grind on was some old 5160 sheet stock. I’ve had good success at heat treating normal blades from this steel using the following recipe in my even heat kiln:
Slow ramp (700f per hour) to 1530f
Soak at 1530f for 15 minutes
Edge quench in canola oil heated to 135f
Fully immerse blade until completely cooled
Temper at 350 for 2 hours twice
My question here is, will this heat treat process work for a straight razor without causing warping or ruining the steel with how thin it’s ground or would I be better off using a torch and magnet, heating from the spine through to the cutting edge of the razor?
