Hi guys, I've recently attempted to build a HT oven but am having some issues. Tried reading a bunch of threads on here but have had no luck. I'm going to try and include as much info as possible so sorry if its kind of long and disjointed.
The inside of my oven is 15.5" x 4" x 4.5", so .161 cubic feet. Using an Inkbird PID from amazon. I'm running 120v, 13amps, 1500 watts. The bricks are cemented together with furnace cement. According to my calculations I'm getting something like 9600 w/cu ft which is more powerful than most commercial ovens, the 120v Evenheat KH 414 is ~7200 w/cu ft for reference. Is it possible I made it too powerful which would lead to PID issues??
Its having trouble at higher temps, hasn’t reached anything over 750C and that was after letting it run for about 2 hours. Heats up fairly quickly to about 450c, then really slows down. Took around 18 minutes for it to get from 500 to 600C
. After that it just crawls at an abysmal pace.
I read a bunch of threads including the "Everything you wanted to know about PID's but were too afraid to ask" and thought I had a basic understanding, but when I played with the PID settings (proportional band, integral, derivative values) I still couldn't get it to keep climbing. With a set point of 500C I’m able to stay within +/- 2 degrees, so I’m not sure if the issue is with the PID or not?
So its an insulation problem then? If I cut power at 650C it loses ~1 degree C each second. No idea how this compares to others.
My oven has a sheet metal casing, and to my understanding it's supposed to stay cool to the touch. It's not, it gets really hot after about 45 mins of heating. Stays hot for hours after. I plugged the thermocouple and element exit holes with ceramic fiber to stop any heat from escaping. The door has a piece of ceramic fiber on it as well and seals up pretty well. I don't really feel any heat escaping from those areas when I put my hand nearby. I don’t notice a certain part of the case heating up quicker either, feels pretty uniform.
Even with the holes plugged, would that small of an opening really cause the oven to heat up this slowly?
Makes me worried I may have potentially gotten the wrong bricks? I got them locally from a silverware/metal company (who was trying to get rid of probably a thousand of them) for 1/3 of the price as ordering them online. They were used but were in very good shape, no cracks or chips etc. I was told that they were k-23 soft firebricks. They look correct as far as I can tell and are easy to cut into. Here's a pic: https://i.imgur.com/WL11lLA.jpg
I wired it using this diagram that I found posted on here, with an added fuse between SSR 1 and the toggle switch. I've tripled check the wiring so it's exactly as pictured. Diagram pic: https://i.imgur.com/Ps8Wuyi.jpg
Quick summary: Do these bricks look correct?
Is plugging the TC/element holes with ceramic fiber sufficient? Even if it was poorly insulated I would think with the power ratio it could at least get over 750c??
Basically I’m beyond clueless at this point. I’m leaning toward an issue with the bricks/insulation, which would suck because that means a complete rebuild. Any help or input would be really really appreciated. Thanks in advance
