Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
So with a steel like 1084 once you get it up to the proper temp you can quench it? I have never attempted making a knife but am getting the itch. I have the facilties at work such as drill press, vises, belt sanders, torches, oils I would need for quenching and so forth.Yes and no. It really depends on the steel. A simple steel like 1084 will likely heat treat just fine. There are many experienced smiths who use a torch and differentially heat treat blades (just heat the edge with the torch to temp and then quench). That's why 1084 is such a great beginner's steel. It can be heat treated with a minimum of expensive equipment and get satisfactory results.
Other common steels like O-1 and any stainless steel need more temperature control and longer time at temperature (i.e. you need a heat treating oven or a well controlled forge). O-1 does well with 15-20 minutes of soak time, and stainless steels often need 45 minutes at temperature. This is all but impossible to do with a torch without overheating/underheating. Tempsticks are great to tell you when you reach the target temperature, but won't really help you hold it there. With steels like 1084, that's not a problem because you don't really need any soak.
--nathan
I have made 8 knives total, 6 out of 1084. All have been HT'd with two torches. I set up the two torches a few inches apart, so that the second torch helps heat the other half of the blade, and it's much easier and quicker to reach the temp. Then heat until it reaches non-magnetic and then you're ready to quench. It's not perfect, and I know it's not as hard compared to a controlled temperature, but it got the blades hard enough to skate a file, which was fine for me in my beginning stages.
By the way, I quenched it in about 150 degree canola oil.
Phillip Patton tested the spine of one of my knives in hardness, and it came out to be 38, which is not hard for a knife, but the edge of it was hard enough to skate a file before tempering (Didn't test the edge to prevent the blade from cracking).
Mike's temps are a bit off, but the principle is about right.
I am not a fan of torch HT, but for simple steels, it will work. 1070,1080,1084, 5160, and 52100 will all quench sufficiently to harden with a torch. Of those, I would say 52100 is the most problematic. It is a 1% carbon steel ( hyper-eutectoid) with 1-2% chromium. It has to be heated to 1550F to austenitize. Then quenched in 120-130F oil ( canola is good enough). It has 3 seconds to cool down past 1000F ( the pearlite nose). Once cooled to room temperature, temper at 450F for two hours,cool and repeat temper. If doing a cryo in LN, do a snap temper at 300F for an hour before the cryo.Temper at 400-450F after cryo.
Stacy
Can you heat treat a knife with a torch using temp sticks. Thank you
Being hypereutechtic wouldn't you want to give 52100 an extended soak time to bring all of your carbon into solution?
-Page
