- May 19, 2010
Below is a cut and past from another thread in, of all places, a microscopy email discussion list. Seems those guys like to make things too. Making the "perfect" microscope for themselves.
Here is the post:
The use of a burnt on layer of soft soap to protect the steel at red heat is standard horological practise, sometimes supplemented by a layer of iron binding wire. Slowly raise the temperature, so as to evenly burn the soap onto the part's surface. The soap will melt and the volatiles burn off leaving a black layer. Then raise up to a cherry red and quench. The black layer will fall off leaving a clean white surface with the minimum of damage, and that is easy to polish.The iron binding wire ensured that an even temperature gradient existed across more complex parts, and reduced the chanced of cracking and distortion when quenched.
end of post
I am a newbie. I was also part of a discussion regarding surface prep after heat treat. Seems like this could minimize after HT surface cleanup work. I thought I'd put it here and ask, "is anyone using similar technique on their carbon steel blades? I hope I did not ruin a secret!?!
What is "soft soap"? The kind my wife puts in a pump bottle in the guest bathroom?
Thanks!
Here is the post:
end of post
Thanks!
