- Feb 3, 2013
When heat treating a few knives at a time, after reaching the desired temperature and soak time, do you need to make sure the pyrometer reads the appropriate temperature before each blade is removed for the quench?
Until today, I've only been able to heat treat using a forge and have largely stuck to 1084 to keep things simple. Recently however, I was able to pick up a (tiny) Evenheat oven (good deal on local craigslist) to try stainless steels. AEB-L seemed the simplest to start with, so I banged, out a couple little neckers to try it out. I tend to work is small batches, 4-6 knives at a time as it seems more time-efficient. It's possible my only problem is the lack of both patience and experience, but after removing quenching the first knife, I got tired of waiting for the readout to climb back to the goal temp before moving on to the next one.
Specifically, I soaked 6 knives at 1995 F for 10 min, quenched the first knife, but opening the door caused the pyrometer reading to drop precipitously. I would then let it creep back up to anywhere from 1860-1920 F, but then I would get impatient and move on to the next one, figuring the metal blades were still close to that goal temperature. Is this sufficient, or should I really make sure each returns to 1995 before quenching? If I should be doing the latter, any suggestions on how to keep the temp of the oven up to minimize the wait time? Or some sort of rig to quench multiple blades at the same time?
