Willie71
Warren J. Krywko
- Feb 23, 2013
As I mentioned in another post, going through the very well written and informative stickies gave me a lot of great information, but it took several reads to get the basic concepts sorted out in my head. Here is what I narrowed it down to in the most basic form possible:
Metallurgy 101:
Steel loses its magnetism at 1414f.
Normalizing is the process of restoring the steel to an even, regular grain structure. Grain growth is a byproduct of too much heat. It is common during forging and welding. The specific normalizing temps and rates of temperature change is specific to each alloy. The normalizing processes is achieved by getting the metal to a specific temperature above the nonmagnetic temperature and cooling at a controlled rate. Time at that temp and rate of cooling is known for each steel. Normalizing is similar to annealing, but results in a harder and stronger steel than annealing. See chart here: http://info.lu.farmingdale.edu/depts/met/met205/normalizing.html
Annealing: (Quoted directly from the stickies) Full annealing is the process by which the distorted cold worked lattice structure is changed back to one which is strain free through the application of heat. This process is carried out entirely in the solid state and is usually followed by slow cooling in the furnace from the desired temperature. If I am understanding this correctly, annealing will repair the structure of the steel after cold working, whereas normalizing the steel is repairing the problem with grain growth. Also quoted from the stickies: Stress-Relief Annealing is sometimes called subcritical annealing, is useful in removing residual stresses due to heavy machining or other cold-working processes. It is usually carried out at temperatures below the LCT, which is usually selected around 1000oF. LCT is "lower critical temperature."
Normalizing and Annealing are basically the same process when dealing with low carbon steels, heating to about 100f above upper critical temperature and slowly cooling. Normalizing happens when cooling in air, and annealing is slow cooling in the furnace. When dealing with high carbon steels, there is a a difference, and spheroidizing annealing happens below the critical temperature for prolonged time. It is used to increase the machinability of the steel. Full annealing happens above LCT, but as the carbon content increases, the UCT increases, so the annealing temp is below the UCT with higher carbon steels. See chart here: http://info.lu.farmingdale.edu/depts/met/met205/ANNEALING.html Note the difference between the temperature range in high carbon steels from normalizing compared to annealing.
Hardening or heat treating is going a certain amount past 1414f, usually about 100f or so depending on the steel, then as quickly as possible quenched in the correct medium such as water, slow oil or fast oil, or air depending on the steel. The temp of the quench solution is a controlled variable. This is the process that gives blades and other hardened tools such as files their hardness. The metal can be too brittle at the hardness that is reached.
Tempering is the process of reducing the hardness by basically baking the steel at lower temps such as 300f or 450f depending on the desired hardness (often referred to as Rockwell rating.) It is different from normalizing as the grain isn't put back to its pre grown state, just a reduction in hardness.
The sequence of these processes was provided by Stacy in a post below:
"The things that need to be learned and understood are:
Choosing the right steel - Sounds simple, but picking the right steel for the task the knife will do, and using a steel that fits the equipment and procedures you are capable of using is often not done.
Pre-conditioning the steel for working it - This covers the normalizing after forging and grinding, spheroidization before grinding, and any annealing steps needed for forming and shaping.
Preparing the steel for HT - These steps are really part of the HT. This includes normalizing the steel, and refining the grain. At the end of these steps, the steel should have a fine grain structure ready to be austenitized and then converted to martensite.
Hardening the steel - As said, this is just the continuation of the preceding step. In hardening the steel is taken above the critical point and converted to austenite, and then cooled at a rate to yield the maximum amount of martensite while incurring the minimal amount of stress. The temperatures, cooling media and rates are very specific to the steel type used.
Tempering the steel - After hardening the steel needs to be converted from brittle martensite to tempered martensite. This increases the toughness and decreases the brittleness. It also slightly decreases the hardness, but the increase in toughness makes up for that. Another thing that may be happening in the temper is conversion of retained austenite. This converts to new martensite, and will be tempered in the second temper cycle."
There is a lot more to this, but this is the basic idea.
Metallurgy 101:
