Heating Kydex In The Oven ?
jeepin
I want to tighten up a kydex sheath and right now my only option is putting it in the oven.
Its a neck sheath if that matters.
I just need to know the temperature I need to set it to and for how long?.
Thanks in advance.
If you're just trying to tighten up the sheath, an oven is going to get too hot too quick to do this, IMO. On a finished sheath you risk the rivets pulling through and then you're going to be sheathless. I think the best route for this is a heat gun with a diffuser and being REALLY conservative with how much heat you put into the material. I'm not a veteran in Kydex but I've messed up enough to know what not to do.
Unfortunately I dont have a heat gun,
I do have access to a blow dryer though.
If I hold the blow dryer on one spot on the kydex sheath long enough will that work?, or will it ruin it?.
In have tightened kydex sheaths by dipping them in a coffee cup of boiling hot water and then squeezing it with my fingers and then put it in cool water.
I've used a candle to tweek kydex too. Just keep it a couple inches above the flame and check often with your fingers until it becomes pliable - then squeeze it to the shape you want.
Whatever method you use go slowly. You can always heat more but once you've gone to far and melted it you've got a mess.
Jeepin,
According to Kleerdex, the company that makes Kydex, you should be heating Kydex to between 360 and 385 degrees F for material in the thicknesses commonly used for sheaths. It also says that you should heat your Kydex from 80 - 100 seconds for .093 thickness material. Here's the link to their Heat Treating Technical Brief.
