Whats your definition of "cheaper"? Do you prefer tubes or flats? Do you have a shooting style preference like OTT(over the top) or TTF(through the forks)?
That reply just made me realize how much i still do not know about slingshots lol. I dont really know what tubes or flats are, or OTT or TTF. I will do a bit more research. any good websites with slingshot info? I know theres tons of different kinds. & Well honestly i dont know the price range for slingshots. but under $40 would be good.
I think that's a Simple Shot, Scout. They're on closeout now, frame only for $15. Complete slingshots start at about $25 for their polymer models and go up from there. Some of his custom stuff is beautiful.
http://www.simple-shot.com/collections/flippinout-slingshots-1
Legion has a first gen scout. Simple shot is going to full production of gen 2's now. Im not sure if the first gens are sold out.
Flats refer to when exercise bands such as theraband gold, and pure latex sheet are used for band material. You can buy pre-cut bands or cut your own with a rotary cutter. If your more worried about speed and power than band life go with these.
Tubes refer to just that, latex tubing available from slingshot sites. Usually used in a looped set( one length of tube with both ends attached to the pouch and the middle goes through a hole in the forks of the slingshot. If your more worried about longevity of band-life, go with these.
Everything is a tradeoff with bandsets just like steel is. You have to match up the proper bandset with the ammo weight to get the best life and speed out of your bands. And remember heavier pull NEVER equals faster speed. Bands matched to your ammo and long draw length is what you want.
Tell me your draw length and what your goal is (targets, hunting) and what ammo you think you'll be using and ill recommend a setup.
TTF is when the bands come around the sides. OTT is when the band come over the top. Legion's scout is set up with OTT. TTF would be tied perpendicular to what he has.
Any of the poly offerings from simpleshot or Bill Hayes are solid slings, its just a matter of what you like. Or... you could always go cut and carve yourself a natural tree fork.
As long as your in the states and interested, send me an email with your address. Ill send you a finished and banded up natural fork, and some 3/8th bearings.
Oh i'd probably go with theraband or pure latex for the power. Unless tubing gives me enough power for small game.
To measure my draw length, i assume i should measure from one arm extended to the point near my chin? I mainly will be hunting small game like squirrels. And not familiar with ammo either, but i know marbles can be used and metal balls as well. Could you give me a recommendation?
So TTF and OTT don't have any pros and cons over the other? To me, whatever allows me to develop the best accuracy seems the best.
I am in the states and interested. You have extra homemade slingshots? That would be awesome!
Btw, thanks for all the info and help!
I used to use one of these and found it OK. Why do you prefer the non-braced versions? Once acclimated to, do they perform as well? I wonder if I should give one a try.
You probably already know this but, you wont be able to hunt right away. Slingshot shooting takes a lot of practice to be accurate. You need to be good enough to get head shots. Thats the only way you will get clean kills. If you cant hit a two inch circle consistently from 10 yards then keep practicing.
You can hunt with tubes but you will be able to get slightly higher speeds with flats.
Yes from your hand to your anchor point. Mine is right below my ear, yours may be different.
If hunting, lead is the best option. .40- .50 cal is a commonly used range that hunters use. A good setup is .44 cal for hunting and .5" steel for target practice. They weigh almost the same so you can use your same hunting sling to practice with a less expensive ammo.
I shoot better with OTT but others are different. Your most accurate with what your most comfortable with. OTT just seems more natural to me. YMMV.
Just shoot me an email with your address. Happy to get you started.
Alright good to know. Will stay away from 3/8 for hunting.I'll use marbles but not very often. I have a ball bearing supply store in my town so I can get bearings a lot cheaper than most people. 3/8" and 7/16" is what I use for practice (mostly all i do). 7/16" can be used for hunting in a pinch to. 3/8" is a bit light for anything other than birds.
You'll need to make a catchbox so you dont lose your ammo. They rely on a loose cloth back to absorb the impact so your ammo doesn't ricochet. It just hits and falls straight down. My outside one is old dresser-type thing with a folded blanket stapled to the back. My indoor one is a milk crate with a couple old sweatshirts in the back. And fun noodles on the sides so I dont bust it up.
Did you send me an email? I didn't get one...
