I need some assistance...
I bought a new Kershaw RAM blem and I love the knife but the button is pretty stiff and hard to use. So I tried to take the G10 scale off to look for a problem (and maybe take one of the two springs out) and stripped the last T6 screw.
As soon as it started to strip I tried using a soldering iron to heat the screw to loosen any loctite (if present) and pushed really hard to fully engage the edges, but didn't work.
I tried using a T7, didn't work.
So I looked on YT and saw someone recommending using a small flathead screwdriver and wedge into opposing "corners". Didn't work, but it did bend the sides of the blade and strip the screw a little worse.
My father-in-law is a retired machinist and loaned me a screw extractor (looks like a left-hand drill bit) that you twist with a tap handle, didn't work. In fact I think the extractor is for a bigger screw size because it basically acted like an auger and the stripped T6 is now a perfect circle.
When I stripped a screw on my Kershaw Skyline clip (non-blem, purchased from the same website) I used a Dremmel to cut a notch in the screw head, and then used a flathead screwdriver to remove it. No problem because the screw was raised above the clip. With the RAM the screw is countersunk into the G10 so this isn't a good option.
Any ideas? I would have just mailed the knife to Kershaw, but this is a blem and I don't think they are obligated to fix it. This knife is brand new, never carried, and it's killing me that I may have to send it somewhere! Any ideas?
-StaTiK-
-StaTiK-
