- Oct 27, 2005
I have 9 small ball bearings made out of 52100. The bearings are about 2" in diameter, with little 1/4" balls in them. 11 balls in each one. I took them apart to do a damage analysis. What I want to do is make canned damascus with 1084 powder to fill all of the voids around the bearings in the can. I'm thinking of getting some thin, long mild steel channel to lay them in side by side. I'd weld a cap on each end to contain the powder as I tap and pack it full of powder around the bearings, filling the can up. I'd then put a top over the entire thing and weld it shut. I have a few questions, since I haven't tried anything like this yet.
Will I get good contrast with the 52100/1084 combination?
Should I add some other powder metal instead?
Should I cut up some 15N20 into little pieces and put it in randomly with the 1084 powder and bearings?
Do I need to have a hole drilled in one end of the welded up can?
Once I have it welded up, I'm going to grind off the mild steel can and then etch it to see the pattern. If I like it, I'll keep some of it like that. I'm also going to twist some of it, or all of it, to see what happens to the pattern when I do that.
Any suggestions, beyond what I've already asked?
