Hello all,
I am having some issues with squaring the shoulders on the knife blades I have on hand and I have to think there is a simple solution to this.
I purchase all of my blades premade and they come in hardened. This makes squaring the shoulders of the blade problematic and quite time consuming. I have recently gone through 4 files on the last 3x blades I worked on.
Now I don't mind replacing files when needed but averaging about 1-2 files per blade I can see this becoming an expensive issue later on.
I am now on the list for one of bruce's file guide and I am looking for alternatives to making squaring the shoulders of the blades a more efficient and cost effective process moving forward. As it stands I see 2x options that will work with my budget and available shop space:
1.) Buy a torch and anneal the tang to soften the metal then square the shoulders with the files. I am concerned about ruining the hardening of the blade in the process. (I've seen a few threads on this already)
2.) Buy a small 1x 30 or 1x 42 sander and use that with bruce's guide to true the shoulders. This setup could also help with stock removal on the handle but I haven't seen many positive reviews for this belt sander setup.
Ideally I would like to buy a 2x 72" system but I currently don't have the space for a larger setup like that.
What has worked best for those out there when it comes to this step on knife making? Any input on this would be greatly appreciated.
