- Feb 1, 2001
Hello Gentlemen,
I'm a new maker and I bought a used Paragon SC2 from a friend who is a knife maker. This is a little tiny kiln designed for jewelry but will work for small knives requiring heat at or below 2,000 degrees. I can treat all my 10" and shorted blades till I progress to longer ones. I'm wondering a few things about 1084 I got from Aldo. He said to normalize it at 1600. My questions are:
* How long do I hold the steel blade at 1600 for?
* Does it matter how fast the Paragon heats it up to 1600?
* Is cooling time critical? Can I simply open the Paragon door, grab the blade and let it cool on my concrete garage floor? Wave it around in the air till it is cool to the touch?
*When doing the actual heat treat treatment, I'm programming the Paragon to 1500 degrees. Once it is there do I need to soak/hold it at that temp for a certain time? Again, does it matter how fast it heats up to temp?
*Do I then just open the Paragon door, grab the blade and immediately stick it in my canola oil till it is cool?
Anything else I should do? Thanks for the help!!!
