- Feb 19, 2021
Hi all, just wondering how to get a blade shaving sharp. I've tried most options other than a belt machine (don't have a shop). I have the Lansky fixed sharpeners that absolutely suck in my opinion. All I've done is ruin knives by taking off too much metal. And I was being careful. Furthermore, you can't really use the 17 degree option because you hit the screw head on side. So I've tried just getting some basic inexpensive two sided stones and free handing with the Worksharp pocket sharpener that has ceramics, diamond and strop on it. I have tried with a marker to make sure I'm hitting the right spots. The only blade I can get fairly sharp with easy is the Buck 110 (and that is 440C on a 3 dot 1980). Should try sharpening the opposite direction? So rather than pushing the blade on the stone, reverse and pull it! Seems like that is actually the logical way anyway. I know creating a burr by push sharpening is the goal, but even when I do that and remove the burr, it's still only moderately sharp. And I know blade geometry plays a part. That is, full flat grinds should be easier to get sharp like the Ontario RD's and Tak 1 or hollow grinds like Buck's. But the thinker saber grinds are not easy like the Bencmade 551 and Leatheman K502X for example.
