Monofletch
Basic Member
- Jan 14, 2010
hello.
I recently discovered yellow jackets entering the house at the air conditioning cable hole. First time I sprayed where they were entering- the utility room downstairs had about 100 yellow jackets buzzing around. I sucked them up best I could with the Rainbow vacuum (water tank) and sprayed again. I got about the same result. 3rd time a little less. 4th a handful. Next day even less. I waited a whole day then sprayed as far up in the hole as possible and got 3-4 bees. I waited for it to dry then shot a bunch of expanding foam in the hole to seal it up.
I can not see the nest it is back behind the finished part of my basement. I am still getting 1-2 big fat yellow jackets a day crawling on the concrete under the light. These are much bigger than the others. They seem to be half dead or “on their way out”.
Have I beat them or they just slowing because it is cold outside? I figured the big ones might be the last bit since they have no way out.
Any advice? I hate to pay a guy $400 if I got them under control.
