Thanks, I used the sharpie method to get where I am now. The trouble is that the base of the blade seems to have been neglected when ground. I may have to pay a knife guy with a belt grinder to work the base. Or just ignore it. The knife will be plenty usable as is. It just bugs me. I was just watching a YT video where a guy was claiming the ice hardened Henckel should be 20 degree and the carbon steel Japanese chef knives should be 17. I suspect re-grinding will ruin the ice hardening too.
Hi,
beltsander is not required for regrinds,
its not too hard or time consuming with a stone if you spread it out,
get a dollar tree stone, dunk it in water,
take the light side (seems to break down easier),
and scrape everyinch with a nail
or a sharp rock
or the corner of another dollar tree stone,
rise yourself some slurry
then with two hands
scrub the problem area for a minute
then take a 5-15 minute break
if your arms are in any way sore, use much less force next time
if you didn't even feel it, use more force next time
just make sure you only do one minute at a time and don't overexert your arms
to the point they're sore, the rest of your week will be painful
also grind down the bolster as required
you don't have to do it all in one session , you can spread it out over an entire week or month
I mention dollar tree stone because its a hard stone 1x2x6inch
it can take a lot of force without getting damaged,
and using a lot of force speeds up grinding
also the brick and mortar stores seem to have them in stock again
