- Aug 28, 2014
Hey Folks,
After having gotten superb direction and information from this forum, I placed an order for an HI M43 and I finally have it here in hand so I am posting a photo review if anyone is interested. The blade is amazing and if you don't already own one and you are on the fence I can truly agree with the members on the forum that you should indeed pick one up. Its a functional piece of history and one of the finest hand made blades I have ever seen though admittedly I am far from an expert so take that into consideration as you read my review.
Himalayan Imports M43 Khukuri Official write up from their site (http://yhst-7333098713883.stores.yahoo.net/index.html):
M43
Based on the WWII khukuri, the M43, which was designed as an update of the Mk II which was basically a WWI design. The new knife had a stronger grip attachment system, a wider pommel and better bolster design at the blade. The balance is slightly more forward and the blade could arguably considered stronger.
My Khukuri's specs are as follows:
Overall Weight (knife only): 2.2 lbs.
Overall Length: 19"
Blade Length (not accounting for curvature): 11 7/8"
Blade Length (allowing for curvature): 12 1/8"
Blade Width (at thickest point): 3/8"
Handle Material: Horn
Here it is in the sheath and out:
I'll come back to the blade itself, but first I will address the sheath and accessory knifes.
The sheath itself I am not impressed with, the blade fits quite loosely so that if worn on a belt - a light run would cause the blade to bounce and anything faster would be dangerous as the cutting edge would be able to cause injury. It also had two significant scratches to the leather, obviously not hindering the functionality, but for a new knife this was a let down as it was the first thing I saw upon unboxing the blade.
Here are the aforementioned scratches, they don't come out much in the photos, but are very noticeable in person:
The chakmak and karda are well done, with the Karda's edge a bit dull for my tastes, though fully usable. My only gripes with them are that they are both marked up on the handles:
Again these are cosmetic issues and less an issue than the sheath, but still not something you want to see on a new purchase.
Now the blade itself I could not be happier with, its superbly balanced forward for what it was made to do - chopping things. I cleanly cut the box it came with in half with a good swing of the blade. It is well crafted to say the least, I cannot find a single mistake that is obvious on the blade - the only issues are small scratches and nicks here and there that are to be expected on a hand made carbon steel khukuri. It is a hefty blade at 2.2 pounds and the the thickness gives it a sense of durability I have never seen nor felt in a blade:
I would not pause to put it up against any chore reasonable for a strong blade.
The markings on my blade are as follows if you are interested:
The handle as mentioned is horn and the fit and finish are top notch:
Due to the weight of the blade it is most feasibly a chopping tool, though I have no doubt it would make a good self defense weapon, there are certainly better choices for that. The service and communication were excellent from HI and I am highly satisfied with the purchase. It is easily the strongest blade I own and I look forward to putting it to use outdoors. My thanks again to the forum for your assistance and I hope to someday be posting another review on my next HI blade - if anyone has thoughts on what would make the next best choice please do comment below.
Cheers, - The0bvious
M43
Overall Length: 19"
