I'm looking to upgrade my heat-treating capabilities. Currently, I can successfully heat-treat (12" max) simple carbon steels in my forge, using a thermocouple and manual temperature adjustment (about +/- 50 deg).
I'd like to build a high-temp salt pot setup similar to the one shown in this thread: http://www.bladeforums.com/forums/showthread.php?t=647313, but long enough to accomodate sword-length blades.
I have a few questions, but here's my current plan. Please let me know if you see anything in my proposal that is obviously crazy (or even just sub-optimal)!
- 4" ID, 4.5" OD, 36" long 316L welded pipe: (http://www.mcmaster.com/#stainless-steel-pipe/=44tbsf).
I'm going to have this professionally welded to a stainless base. Planning on coating the outside of the pipe with ITC-213 for added durability. Anything I should let the welder know, specifically?
Any comments on this? Any reason to avoid the welded pipe and go with seamless? is the ~1/4" pipe wall thickness really necessary, or could i *safely* go with the 0.12" thickness?
Anyone know of anywhere I could get this any cheaper (but the same quality)?
- A T-Rex venturi burner (http://www.hybridburners.com/pics/trex-903.jpg)
- This PID controller: http://cgi.ebay.com/UNIVERSAL-PID-T...ultDomain_0?hash=item2ea3ed7104#ht_1690wt_990
- This solenoid valve: http://cgi.ebay.com/1-4-Electric-So...ultDomain_0?hash=item439a935b30#ht_2063wt_765
Any comments here? I've never put together a PID/Valve system before, So this is the part of the project that I am the fuzziest on. Do the controller & valve that I linked above look adequate? Any better recommendations? Any tutorials or comments on putting together a PID/Valve venturi burner?
- Building the furnace out of a hot-water heater shell, 1" wool + satanite + ITC-100.
- High-temp salts from Darren Ellis.
- I need a plug for the salt-pot. Is a straight 1" bar good enough, or does it need to be tappered?
I've tried to do as much reading on the subject as I can, but if you have any relevant links, please send them my way. I really appreciate any & all help you folks can give.
Also, I am well aware of the safety risks involved here, so please keep the "You'll burn your face off!" comments to a minimum. ;]
Thanks,
Dustin
Thanks,
Dustin
