Have been using a s30v Spyderco PM2 to cut open bags of mulch lately. Maybe I sharpened the edge to too small degrees. Man it microchips like hell. I imagine a hinderer xm18 3.5 would be a better choice for the task.
Great example of cutting. Most EDC tasks can be accomplished pretty well with a good cutter, slicy is probably most associated with food prep, or separating tight material like a thick mat or heavy rope. In general a slicy knife will work better in most situations where a good, thick BHE cutter (but not slicy) would excel at chopping and piercing due to a heavier tip and thicker edge profile.
You probably wouldn't feel underknifed with a spanto if you're not planning any kitchen work, they cut really well once reprofiled to 20 deg per side. For a one and done though it wouldn't be my 1st choice. In my case it was my 1st Hinderer, now I have 5 but only 1 spanto.
I carry an XM-24 most all of the time and have it sharpened with a 17 degree mirror polished edge by my Wicked Edge.
OH, c'mon!! "seperating cheese"?! You know you want to CUT the cheese!Bit off-topic, but what are examples of tasks associated with cutting vs slicing? Cutting as in severing rope and slicing as in separating cheese?
Cutting is where the edge separates a material. Slicing is when a significant portion of the blade passes through the material and has to push it apart. Or at least these seem to be the common definitions.Bit off-topic, but what are examples of tasks associated with cutting vs slicing? Cutting as in severing rope and slicing as in separating cheese?
You cut paper, as the overall blade geometry makes little difference in difficulty after the edge separates the material. You slice an apple or a potato, or hard rubber, or anything else where the blade can get stuck.
