- Nov 22, 2020
Hey everyone.
I intend to do a lot of hollow grinding and was researching the height of the grinds based on the diameter of the wheel and thickness of the stock.
I have come across a few charts/tables showing different heights for the same parameters.
Using this : http://dcknives.com/public/grind_angle_concave.php
and the formula from it I deduct that it gives the perfect calculation from the very edge of the stock (or where the cutting edge will be ground from) to the maximum height the wheel can offer.
Now obviously you can keep grinding upwards but will be left with a very flat space on the grind right after the cutting edge.
My question is if it will only affect the strength of the blade (and weight) because extra material is removed or will there be other negative effects from grinding too high?
I hope my question is presented well enough to understand
Regards from South Africa
Theo
Theo
