Okay, I’m getting close and can see the finish line. Or so I thought... I mounted my 6”x3” serrated contact wheel to the tool arm and thought it was really close to perpendicular checked my drilled hole with a machinist square) and it seems balanced. As I got the rail assembly closer to mounted, I could see some indicators that made me think the rubber on the wheel wasn’t perfectly even-possibly thicker towards one side of the wheel? I later checked the bolt with a machinist square and it’s definitely not perfectly square, but when running with the belt on it, there wasn’t any noticeable “wobble”, etc.
Then I got the rail assembly mounted. I decided to begin surfacing the chuck against the wheel and noticed the process wasn’t as smooth as I would’ve thought it could be... As the handle gets closer to the wheel (more of the rail and chuck are extended below the wheel) there appears to be some bouncing in the extended part. Which makes me think the concentricity of the wheel is off just enough to cause me a problem....
So, any thoughts? Mine is on a KMG and the rail is mounted at around a 45 degree angle. I threaded the 1/2” hole in the tool arm and started the tap using my mill, turning it by hand, to help keep things perpendicular for the first bit, until several threads were there as a guide, then finished by hand in a vise. Thot I had been careful enough, but guess somehow I went wrong... I’m thinking of opening the hole up to a clearance hole and getting a longer bolt and using a nut on the exit side. The bolts I’ve had have mostly a full 1/2” shaft with only the last inch threaded. But, if that doesn’t straighten things up, maybe I’m stuck drilling new mounting holes for everything? That would definitely suck at this point...but I really want this tool to work. Anyone ever have a problem with the rubber on the wheel not being even thickness? I need to narrow down if I have a separate problem with the wheel, as well. Also, how fast do you a guys run your grinder? I have a vfd and had it under 50% by a little ways. I don’t know if faster or slower is better?
Thanks for any suggestions.
Jeremy
