Thought I would post a review of my Big Blu 50 ton press:
Components: Overall the components used are super high quality- The Parker hydraulics, rams and hoses are all top shelf
Assembly: The fit and finish of the assembly is pretty good. Crating/Pallet is pretty good.
Weld Quality: The weld quality is a disgrace to the Made In USA sticker. Several welds were not even fully attached to the metal (note the pictures of the edge delamination). There is no way that anyone could have inspected these welds before it shipped. This was unsatisfactorily resolved with the manufacturer which is why I call this out and share these photos. (see pics below)
Design items I really like:
Overall: Overall, based on the items needing improvement, quality control and price – I would probably not recommend one to another smith. I think if you are in the market for an H style 50 ton press, the Gilmore would be the best one….and if you want a C style, then Coal Iron (although I never used one).
- The overall footprint of the press, specifically where the hydraulic unit sits, foot pedal and casters. makes it easy to move around and store.
- The bottom up hydraulic design does not take too much to get used too (the press I had before was pushing top down and I got used to this new design in a day). The work is at your eye level with this press and that really helps.
- I love the simple die design – it makes it very easy to fabricate your own dies.
- The bronze wear strips for the ways are nicely designed
- The high pressure pump is really manageable to control (meaning when it is pumping at high pressure it is easy to stop where you want to stop)
- This baby is quiet with the 1800RPM motor
- The bottom die holding pins need to be detent style pins as the pins they supply vibrate out. This is an easy and cheap upgrade for Big Blu to include.
- I do not like the electric solenoid design. After using this press compared to others, I would much prefer the old school manual value operated design. I have had one instance already where the solenoid stuck – which ultimately would ruin a piece you are working on or be a significant safety hazard. I am still getting used to the one-way operation (press down and it presses…release and it detracts) but after working with it for a few days, I would prefer the Gilmore press style operation (manual valve).
- The press is a bit slow. I am comparing this to my Batson style home-made (prob 15 ton) press which was faster and I could almost get the same amount of actual work done with it (other than the times you really need to squeeze hard). I am sure I will get used to the Big Blu speed over time, but the Big Blu is slower for sure.
- The top and bottom limit switches need a redesign. They are a great feature in theory, but getting them set where you need them is just a guessing game and the overall design of them does not allow them to be spaced close enough together to work well. For example, say you want to take a 3/4” thick billet down to ½”……your opening (based on the design of these switches) cannot really get any tighter than 3”, which coupled with the speed makes this frustrating. I will be coming up with my own, better design for these limit switches. This could be an easy fix if I just reposition the arms, or more complicated if I need to fab something up (see pics below as the unit comes – you can see as tight as you can get them and then the size of the opening that it allows for)
- They need to fab and install a front scale shield. You will have scale all over your rams if not. I will likely fab one of these myself for the machine. The rear shield works ok, but it needs to be another inch longer as scale will still vibrate off the back shield and find its way back on the cylinder rams.
