Bill DeShivs
- Jun 6, 2000
Instead of turning the whole grinder sideways, why not just make a vertical tool rest and hold the WORK sideways??
I just saw an over center a week ago and like the idea, but there wasn't enough detail in the vid to see how to implement it. Have any drawings or info that might help me understand it?
Otherwise, ratchet could be good too. You make a good point on the two handed issue.
Brock- I use a Hardcore, a Pheer, and a Grizzly- all 2" X 72".
If I need a horizontal, I stand on the wall.
If I were building a horizontal grinder I would use 3 inch wide wheels and run 2 inch belts.
You can then move to a fresh bit of belt with a tweak of your tracking wheel, no work rest adjustment needed. .....
If your work rests are easy to move - and keep square. I wish mine were :-(Considering the extra cost of 3" wheels, I'd just go with standard 2" wheels and move work rest up to use other parts of belt.
Mine will be. Do you currently use a horizontal grinder?
I do have one, it was a one off and a first by someone who usually makes vertical grinders.
It does the job and is very useful, it didnt cost too much either. It gets used more than my vertical grinder which now just does bevels and sometimes profiling when there is a lot to remove.
Now I have been using it for a year or two there are many improvements/changes I would make if ordering/making another.
3 inch pulleys and better (more easily adjustable) work rests being the main improvements. I would probably use a smaller motor too, 2hp is way more than you can use on a horizontal.
I would still recommend using 3 inch wide pulleys, on your small wheel attachment at least.
................ I would probably use a smaller motor too, 2hp is way more than you can use on a horizontal.
